mystery hole
Started by RTSE440, October 26, 2022, 03:48:29 AM
RTSE440
Any ideas on what this hole is for it's on the inner guard R/H side it's the one in  between the 3 double pleats
70 sublime
It will be for either the sound deadener that goes on the firewall from the inside the car or one of the mount holes for the heater A/C box to mount to the firewall ?
RTSE440
Quote from: 70 sublime on October 26, 2022, 06:02:12 AM
nope it's not for the deadener as they have a counter sink hole for the plastic nails they are the ones you can see above and to the side of that hole and the ac/heater box doesn't mount there either it's to far right. it's not a small 1/8 screw hole either it's larger i was wondering maybe it's a retainer clip hole for the antenna cable I'm not sure which route that cable takes either. thanks for your reply anyway sublime i always appreciate your input
cdr
my 68, your antenna is correct ,
70 sublime
The antenna cable clips on top of the lower dash frame under the glove box to get across to the radio
purple70rt
For power trunk vacuum line. Runs from engine to the switch inside the glove box. Only had one that had this option. Parted out in the late 80's.
RTSE440
Could this be the guilty party for the mystery hole ? Where do you bolt this too under the dash ?
Quote from: RTSE440 on November 16, 2022, 03:31:37 AM
no ,  thats  the cold air out side air ducting  cover , for the ac heaterbox
think your mystery hole has been  previous owner added for some reason some time in the past  , from the picture looks to have been drilled out side in , because the ac heaterbox was in place
RTSE440
Charger_Fan
Tan Top, I'm impressed! Looks like you identified that spot 100%...I couldn't have done that from those initial photos.  :cheers:
Kern Dog
The title of this thread is misleading.
It could have meant so many other things.
* A strange and funky night club.
* A choice made in the dark when drunk and lonely.
* The one place that you regret visiting, yet might visit again.
RTSE440
Quote from: Kern Dog on November 22, 2022, 02:34:50 AM
option 2 guilty lol
