Brain Damage @ the track
Started by cdr, January 07, 2022, 05:40:11 PM
cdr
well I finally made it to the track, SAME FRIGIN fuel pressure problem as before GERRRRRRR, BUT I pulled 3 wheelies LOL, MPH was down at least 4mph because of fuel pump problems, still ran a best of 10.93,,,,,,,,1.51 60 ft, also got to race a new Super Stock Challenger, he kicked my a$$,,I cant duplicate it on the street,you can hear it, on the data log it spikes very fast through out the run from 20 psi back up to 50, in a 1 second veiw in the log it does it about 4 times Yes 1st 10 smile ,, and I remembered to shift LMAO
cdr
cdr
Todd Wilson
XH29N0G
Wonderful!
I really enjoy what you share and really like your car.
I don't want this to sound bad about the challenger, but I like your car much better and the sound much better.
Thanks.
:cheers:
Or maybe it protects us.
bakerhillpins
Nice runs.  :cheers:
Quote from: cdr on January 07, 2022, 05:40:11 PM
Rather than have you rehash things for the Nth time, do you have a thread on here where you're discussing the situation and steps you've taken?
One great wife (Life is good)
96' VFR750 (Sweet)
Capt. Lyme Vol. Fire
BSB67
Very nice Charlie.  Good weather down there on track day?
11.68 @ 120.2 mph
Q5XX29
dakota_gt on Instagram
 awesome stuff !  charger looks mean   :coolgleamA: :2thumbs:
bummer about the fuel  pressure , might of missd it  in one of your previous posts , but what fuel pump  tank / lines set up do you have ?
cdr
Quote from: BSB67 on January 08, 2022, 06:06:56 PM
Thanks Russ ,YES very good, right at -1300  to - 1000 ft on my runs, all that said, the car ran its best yet, BUT with my fuel pump issues I think it slowed it down quite a bit, I am Still VERY pleased & happy with the results so far, No Roll cage ,this car is a drive it anywhere street car, AC, OD, 4.10 gear, 4100 lbs ,drove to & from the track again, 140 miles, drove there, put the long runners on & let the tires down to 20psi, all of 5 minuets work,the 512 is getting tired, been leaned out so many times from all the fuel problems I have had. I am VERY Happy though !!!!! :)
cdr
Thanks everyone for the positive responses, I have a Tanks Inc EFI tank with a Walbro 450LPH pump, return system, at 1st I had a 30 amp relay in the glove box area for the pump, time before at the track fuel pressure was spiking 0 to 50 psi the entire run, got home & found the plug to the relay was melted some, redid the set up with a 80 amp continuous duty solenoid in the trunk close to the battery & fuel tank & put a 450 lph fuel filter on it, did lots of fuel volume test & everything looked great I thought, tank was almost full for the runs, has to be I have a bad connection inside the tank at the pump or a defective pump, will drop the tank & let Y'all know what I find.
BadA55charger
That's awesome!!!   Love your build and your twist on things....such cool package you built and designed.  Hope you work out your fuel issues but it sure runs strong now!   Congrats.
INTMD8
Great launch pic  :2thumbs:
Interested to see what you find with the fuel pump.
67440chrg
Dang cool car and fast too. Congratulations on the best pass yet and it sounds like it will be even faster soon.
kent
Kent
WHITE AND RED 69
Awesome!!! That baby is hauling!
Bummer about the fuel pressure issue but that's still a damn good time and even cooler that you drive it there and back.
1969 Dodge Charger R/T
1999 Jeep Grand Cherokee
1972 Plymouth Duster
Having that car lift the tires straight without a roll cage is DAMN impressive. I cant do that. Mine twists way too much even with 2x3 weld in frame connectors that are tied fully to the floor.
cdr
I was sent another picture, Had to share with Y'all, it made all the work on my street car worth it, puts a big ole smile on my face even though I still have the fuel pump issue
kent
Kent
funknut
Great pics!  Car looks mean!  :2thumbs:
Quote from: cdr on January 24, 2022, 10:06:38 AM
new favorite picture ...shame no sound with that one  ;) :cheers: :2thumbs:
BSB67
That's a nice pic.  What's your 660 and trap mph?
11.68 @ 120.2 mph
cdr
Quote from: BSB67 on January 29, 2022, 05:06:29 PM
660 , 100
1/4 , 120
On the log the fuel pressure starts dropping off & on at about 300ft, in 2000ft air my MPH has been 123, but that was also with fuel problems.
BSB67
Yep. History and the data suggest top end fuel delivery.  It looks like your 660' mph is pretty close to normal, right?
What do you think is the root cause?
11.68 @ 120.2 mph
cdr
Quote from: BSB67 on January 31, 2022, 08:46:52 AM
The 660 was about right, in 2000 da it ran 98 MPH, I pulled out the intank pump to check the wiring, all looked great, some months ago I did a volume test AT 50 psi as Dwayne had suggested & it had plenty of volume, BUT I am going to go to a -8 from a -6 supply & replace the pump even though all looked good, if its not a defective pump it has to be the -6 line is to small I hope LOL :)
cdr
apparently I REALLY under estimated the fuel this motor needs.
INTMD8
Hope it works out for you.
I've ran -6 at well over 1000rwhp.  (And have I believe the same pump with a -6 line on my car at 595rwhp on E85).
If you do have the same pump/tank setup as me (Holley/tanks inc), you aren't going to get anything out of a -8 line over the restriction of the fuel sender that goes in the tank.
I drilled/ported the outlet of that part (that the pump connects to) as I believe it measured more like a -4 internally.
cdr
Quote from: INTMD8 on January 31, 2022, 11:47:25 AM
Thanks, I had checked all my AN fittings & they were the correct ID, but you are correct on the tanks INC pump module, it has an ID of .240 & a very sharp edge bend, my AN fitting is .270 id, will that fix it LOL, all I can do is try it with the new pump, thanks again .
Just went out & drilled it to .290, it gets pretty thin, took a ball bur & radiused the turn, waiting on the new pump then back together.
INTMD8
Quote from: cdr on January 31, 2022, 12:05:32 PM
I don't recall what size I drilled but did the same, radiusing with a ball carbide. Can only help I think  :2thumbs:
cdr
My question to you & NOT meant in a smart ass way, BUT these cars with 595 rwhp & over 1000, running -6 lines have they run a 1/4 mile at the track, I could run mine on a chassis dyno all day long & my fuel problem would not show up.
INTMD8
You could or you did?
I've not ran my Charger at the track since it's in the body shop. It got rear ended on the way home from dyno tuning it.
Even if my car had a problem at the track it wouldn't be due to the fuel line (a fuel line isn't going to flow perfectly on the dyno and be restrictive at the track)
But yes, I work at a performance shop for the last 21 years building/calibrating cars.  So, long ago when we did more 4th gen F-body's we would use the stock fuel line on many twin turbo cars at over 1000rwhp, 8 second, mid to high 150mph trap speeds. Datalogging solid 1-1 boost referenced pressure.
Ran a -6 line on my twin turbo LT1 1996 camaro.  Stick shift car that ran 9's in the quarter, just under 150 traps and just under 200 in the standing mile.
Tons of naturally aspirated customer cars at 500-600rwhp.
With EFI fuel pressures I wouldn't personally bother with changing a -6 feed line unless I was targeting 1200-1600hp.
INTMD8
Here are some mopar examples-
https://board.moparts.org/ubbthreads/ubbthreads.php/topics/604960/how-much-hp-will-3-8-fuel-line-handle.html
A 3/8 line supports quite a bit even in carbureted/low pressure applications.  It can support much more at EFI pressures.
If you want to test if it's the line just put another pressure sender or pressure gauge right at the sender outlet.  Compare pressure at the tank vs at the rail. (you'll see it's dropping as well, not just losing 30-40psi across the line).
cdr
Quote from: INTMD8 on February 01, 2022, 12:22:54 PM
I dont have as much experience as you BUT I have been doing efi since the 80's, I have seen lots of stuff NOT show up on an engine or Chassis dyno, but rear its ugly head up at the track & the other way also, no I have not had my car on a dyno, a SHORT balst on the dyno will not show anything of the problem I have, all that said is mute, but I think your are onto something with the pump module fitting size ,all I can do right now is make some changes & see what happens, I am VERY sorry to hear your car got run into, that just sucks !!!!! keep me posted on the progress
cdr
Quote from: INTMD8 on February 01, 2022, 12:58:15 PM
I have done the volume test at 50 psi & it flowed IIRC 110 gph @12 volts, what can I say LOL :) I will retest when I get it back together
INTMD8
The only difference I've seen between dyno and track with fuel delivery is slosh uncovering the pump or pickup.
It's flowing within a couple percent of the same fuel on the dyno as it does at the track so if the line is fine on the dyno it will be fine at the track.
For comparison, my Charger peaked at 492lb/hr fuel flow on the dyno.
If you don't think several seconds of wide open throttle in high gear on the dyno isn't going to show you any problems may I suggest you give it a try?
I see fuel delivery issues on the dyno on -nearly- a daily basis so certainly useful for diagnosing such things.
The test I'm proposing wasn't a volume test, it was moving your pressure sensor to the sending unit (which when it drops as well would rule out the fuel line as the problem)
Of course it's your car to do as you like with, I just think your problem lies elsewhere.
cdr
I pulled the fuel pump & found nothing wrong with the wiring or pump, went ahead & got a larger volume pump & drilled out the sending unit pump line connection as it was much smaller id than -6 should be at the recommendation of Member INTDM8 as he was correct on that info for the Tanks Inc set up,I also was using a stock 3/8 steel line that has all the tight bends in it, I already had some new -6 efi hose so I replaced the factory steel line with it so no more bent up steel tubing,did a volume test @ 50 psi & it flows about 120 GPH now @ 12volts ,will make it back to a track rental soon.
BSB67
11.68 @ 120.2 mph
