Daytona battery tray
Started by BS27ROB, June 22, 2021, 04:19:37 PM
BS27ROB
I tried search but couldn't seem to find the answer. Should a Daytona battery tray have 2 or just 1 brace underneath the tray. I'd swear I saw a picture of a tray that didn't have the front hole. Maybe Gene's thread.
nascarxx29
1969 R4 Daytona XX29L9B410772
1970 Coronet RT WS23UOA224126
BS27ROB
Thanks Dave,
That wasn't the bracket I was referring to. I found a picture in Gene's thread.
hemi68charger
Yeap, just one support... The vacuum can for the headlamp hose harness goes on the battery tray. A second support bracket would fit probably......
Houston Mopar Club Connection
not wanting to hijack this thread , never realised that before a Daytona only has one lower support bracket , thought all second generations had two ,  unless  it was a  running change  with the later built cars like  the extra floor plan plug & one large battery cooling hole ... a hole is not even drilled for the second bolt either   :scratchchin: :popcrn:
held1823
mine shortly before replacing the inner panel
you can see where the core support had been changed, but the vacuum cannister and battery tray are original to the car
Ernie Helderbrand
XX29L9B409053
hemi68charger
Quote from: held1823 on June 25, 2021, 12:58:50 AM
Guess I need to look at my Daytona more closely !!!!  ::)
BS27ROB
Thanks for the pictures Ernie, mine has 2 lower braces as well and I thought possibly it might have been changed at some point. Looking at your pictures it seems mine probably is the original. It is just like yours with the front brace barely clearing the vacuum can.
BS27ROB
Quote from: hemi68charger on June 25, 2021, 08:05:34 AM
Troy, if you get a chance to take a look at yours I'd appreciate if you could let me know what you find.
70 sublime
Wonder where the battery tray with only one brace hole came from ?
All 69 Chargers should have had the two braces I would think
Is it just a factory boo boo and the guy putting the 69 Charger tray in on the assembly line only put one brace on because there was no hole for the other brace and that car just happened to be Daytona bound ?
WINGMAN
  Mine has two, and that is the way it came from the factory.   :Twocents:  Wingman     Jay.
69 Daytona XX29L9B409032 , 02 Ram Cummins,
Mopar John
Ours had 2 on the bottom and 1 on the top front on the B5 Daytona!
MJ
BS27ROB
Thank you John & Wingman, I guess I just over thought this. Looks like mine is probably original. I still wonder why the tray on Gene's car only has the hole for one bottom bracket. Maybe one of those Mopar mysteries.
hemigeno
Hi Cy,
Sorry for the delay in chiming in...
The posted photo from my restoration thread did not show the second brace, which should be present on Daytonas.  I'm not sure why it wasn't in place when that photo was taken.  My pre-restoration shots show a bolt hole where the front underside brace would bolt on the inner fender, so it was there when the car was built.
It's also in place now, as you can see from the post-restoration photo below of the two braces and vacuum can.
Hope this helps...
BS27ROB
Thanks Gene, I remembered seeing that picture of yours without the front hole and thought it was another Daytona oddity that I didn't know about. Thanks for straightening me out. It seems I've made "much ado about nothing". Hope you and the family are well.
Cy
