Help identify
Started by Bayareacharger, March 01, 2020, 02:32:56 PM
Bayareacharger
From the grille area I believe. For a 1969. Not sure where it goes. What is it called ?
It doesn't matter how your car looks, as long as you have one.
HANDM
Either a front end lighting harness or vacuum hose clip I would think.
I'm sure someone else will have an exact answer though......
Quote from: HANDM on March 01, 2020, 02:58:40 PM
:iagree:   what HANDM  said !  that's what I think to,  BUT
it  looks different ! sure  my clip things close up  around the harness to a box shape  have four sides as apposed to 3   will have a look later  picture below is what I had on computer already.
hold the vacuum lines / harness to the grill frame,
have seen a few  supposedly unrestored cars with out these  2 clip/ clamp things in that location   :shruggy:
I have them on mine ,    see where green arrow is pointing too !
**** EDIT ****  3rd picture  just found this while searching on net ! shows said clip thingy  , look different from what ( Bayareacharger) posted
