Hilborn EFI at the Track
Started by cdr, February 09, 2020, 12:05:42 PM
cdr
People refer to , "Off the trailer pass",, Mine is "OFF the FREEWAY pass", LOL,170 miles round trip due to LOTS of road closures GRRRRR 1st pass was the best.
11.04 @ 123.07 4100lb race weight, Did some tuning & learned what it does NOT like, I forgot to raise the rev limit & still bumped it, even in high gear. I added & pulled timing & fuel, it likes 37 total timing & so far 12.6 AFR, still no 10.99 pass, I am sure with some more tuning it could get there, BUT thinking about my combination here are some points, it is only a 9.7-1 compression, Max Wedge ports,, HEAVY pig with a 28" tall tire & 3.54 gear, I truly believe that my car needs a 4.10 or there about gear, to do much better on the ET, this is a drive it anywhere true street car DA was in the 400ish
https://youtu.be/zBnsqNXDX88
birdsandbees
1970 'Bird RM23UOA170163
1969 'Bee WM21H9A230241
1964 Dodge 440 62422504487
XH29N0G
Thanks for the update.  Fun to hear about it.
:2thumbs:
Or maybe it protects us.
BSB67
Sounds good, looks good.
Looks like there is no one there?
11.68 @ 120.2 mph
cdr
Quote from: BSB67 on February 09, 2020, 04:52:18 PM
about 30 cars, it was a Track rental for the day $200.
BSB67
Quote from: cdr on February 09, 2020, 06:15:32 PM
I love those.  Last time I did a day of carb and spacer testing.  How many passes did you get?
11.68 @ 120.2 mph
cdr
Quote from: BSB67 on February 09, 2020, 09:00:32 PM
I only got 4, I brought some longer runners to try out but I ran out of gas, me ,not the car LOL, but the main thing was I had a great time & learned some things about my car.
It was a nice cool day, great for me :), I dont get out very much because of the heat down here, one of the RARE pictures of me & my Charger.
Time to update your signature et. Congrats. The bump on the rev limiter cost you the 10.99. Any day at the track is a good day.
cdr
Thanks everyone !!!! here is the 2 pass the rummpity rump race car sound is not my car, it is behind me
https://youtu.be/UNwt-gHukHw
WHITE AND RED 69
Awesome!!! Car keeps getting better and better.  :2thumbs:
1969 Dodge Charger R/T
1999 Jeep Grand Cherokee
1972 Plymouth Duster
Q5XX29
dakota_gt on Instagram
TexasStroker
Awesome...sounds great!  For a split second I thought the DA read out at 4,000 was thinking what is wrong down state?!
Hopefully you can squeeze in on a few more track rentals while it is still cool.  There should be quite a few with TX2k coming up!
Founder, Amarillo Area Mopars
www.amarilloareamopars.com
Founder, Lone Star Mopars
www.lonestarmopars.com
Contact me for info!
Brass
Nice runs!   Car looks great leaving the line!
Canadian1968
geez how are you pulling 1.5 60ft on street tires!!  :cheers:
Quote from: Canadian1968 on February 14, 2020, 07:41:28 PM
Drag radials, suspension, good driver.
cdr
Quote from: c00nhunterjoe on February 14, 2020, 08:50:12 PM
Thanks Joe, all good valid points, except the good driver part LOL :)
great stuff ! I cranked up the volume to the max on that first video  :yesnod: :2thumbs:
Quote from: cdr on February 15, 2020, 12:11:42 PM
1.5 60' with no rear shocks at the time of the pass, and a suspension that is good, but moreso setup for daily driving, begs to differ on your assessment of the driver.
cdr
Thank you everyone & also Joe for the encouragement :)
Nice runs Charlie. The car hooks like a champ  :boogie:
Hoping you see a 10.9xx slip soon !  :cheers:
cdr
Thanks Ron
Made me some 12in ram tubes for my Hilborn EFI, bought some bulk 2 1/2 inch stainless steel thin wall pipe, save myself about 300 bucks, these longer runners should get the car to leave harder & HOPEFULLY get a better 60 foot ,. I even made the bell end, using a bearing press & one of my old drum brake hubs, had the perfect taper to make the bell.
cdr
cdr
