Engine oil pan
Started by q8charger, October 18, 2019, 08:19:27 AM
q8charger
Hello,
I want buy a new Engine oil pan Stock Replacement for my car .I'm using engine 1977 Mopar 440 . I like seam the factory oil pan Capacity quart .
Is it 5 quart or 6 quart without oil filter?
303 Mopar
BLK 68 R/T
Thought stock was 4 quart + 1 for the filter?
cdr
Quote from: BLK 68 R/T on October 18, 2019, 10:50:13 AM
it depends on year,engine size
Q5XX29
Correct me if I'm wrong, but Hemi oil pans are 6 quart, other Mopar V8s are typically 5 quart (4+1 for filter).
dakota_gt on Instagram
q8charger
So it's 5 or 6 quart  Capacity ??
cdr
Quote from: q8charger on October 19, 2019, 04:09:55 PM
need more info, what is the engine & what kind of car
BSB67
11.68 @ 120.2 mph
Quote from: q8charger on October 18, 2019, 08:19:27 AM
Hello,
You want a stock 440 oil pan for a Charger? (B Body)
http://store.440source.com/Oil-Pans/products/54/
https://www.manciniracing.com/manciniracing22.html
q8charger
Quote from: BSB67 on October 20, 2019, 06:08:43 AM
:popcrn:
Only I know it is 440 made in 1977 . I'm using the engine on 1969 charger
Q5XX29
What are the numbers stamped on the bottom of the pan?
Q5XX29
:popcrn:
Glad you are amused. Wouldn't have taken you much more effort just to pipe in.
chargerbr549
This should be the pan for the factory 440 in the 69 Charger
https://www.manciniracing.com/marabigbl402.html
A really nice upgrade would be to use the 70 on up Hemi/440hp 6 qt oil pan
https://www.manciniracing.com/ststheoilpa63.html
BSB67
Quote from: chargerbr549 on October 20, 2019, 09:56:47 AM
Boy, that took all the fun out.
4 qt for a 69.
11.68 @ 120.2 mph
Got to match the existing pickup to the new pan right?  :scratchchin:
Kern Dog
I'm sure that MOST people want to be helpful but when someone pops in with a question and gives almost no information, it is like a guy going to a Doctor and saying "It Hurts" then waiting for the Doctor to ask all of the questions.   :smilielol:
Quote from: b5blue on October 20, 2019, 10:44:22 AM
Yes.
Unless building a pure show car that needs to he factory correct, i would never use the stock 4 qt pan.
Quote from: c00nhunterjoe on October 20, 2019, 03:43:22 PM
Agreed !  :2thumbs:
Best stock style pan for a 440 is the reproduction street hemi pan with a windage tray.  :yesnod:
This one has a 6qt capacity plus whatever the oil filter holds. Mine was right at 6.75 qts with the Napa Gold oil filter. If you order this one get the 3/8 pickup tube which is correct for a 440....unless the engine has been modified for the larger 1/2in hemi pickup tube. All stock 383-440 pans had 4qt capacities except the "971" pan which held 5qts. The 971's came on early 70's B bodies.
https://www.manciniracing.com/ststheoilpa61.html
