fan
Started by elks, September 08, 2019, 04:32:57 PM
elks
Hello do you need a spacer with a clutch fan 440 engine.
cdr
elks
Thanks for the info.
justcruisin
There is not a bunch of room between the water pump and radiator on mopars. The spacer was used on the fixed fan but not with a clutch. There are a couple of different lengths of clutches though. Hayden 2747 @ 3.34"(standard length) or 2947 @ 2.71". Both heavy duty.
