timing issues
Started by 7273chargerguy, May 13, 2006, 10:06:57 AM
7273chargerguy
hey guys i got an issue.for my 318,larry shepherd says to install the distributor drive gear pointing towards the front drivers side intake bolt.so i do it like that and my rotor points towards the same bolt obviously but,on the next page it says to position the #1 spark plug tower pointing right down the middle of the engine.how would this work? it seems your #1 wire would be off by a half inch.maybe I'm just wetoded but if someone knows what I'm talking about could you clue me in?thanx
"yours it not to question why,yours is just to do or die."
N. ever A. gain V. olunteer Y. ourself
71440charger
put your motor to top dead center then mark where your # 1 plug is then put your rotoe button just to the left or right of where # 1 is and slide the distributer in it should turn slightly when you set it in. beacuse of the gears
The Killer Cam
