Tti headers
Started by metcoll, January 06, 2019, 11:02:33 AM
metcoll
I have a 70 charger with a 440 and rpm heads..car is floor shifted auto and has power steering, no a/c..is the 440-178 the proper part for my car...thx
If you want 1 7/8 tubes, then yes. Those will fit.
XH29N0G
I would think 1 7/8 tubes would be a good size for that engine unless it is really modified.  I'm sure someone will correct me if I am wrong.
Or maybe it protects us.
will
I'm gonna hijack, would these be a good choice for a 595 horsepower street 440?
Quote from: XH29N0G on January 06, 2019, 12:54:08 PM
Based on the info given, we know nothing. If that is a rebuilt to "stock" bottom end with 8:1 slugs in it, then 1 7/8 are not the right choice. But we dont know anything other then its a 440 and has aluminum heads, dont even know which eddys are on it, so cant say.
Quote from: will on January 06, 2019, 01:10:42 PM
Most likely yes.
metcoll
It's a 9.5 to 10 to ne compression motor with stage one rpm heads (flow 282@600)240/250 @050 520/547 hydraulic cam rpm intake and 850 dbl.pump carb with MSD..
Quote from: metcoll on January 06, 2019, 04:23:04 PM
What piston part number, what head gasket thickness. What is a stage 1 rpm head? Ive never seen such a thing. There are either 84cc or 88cc rpm heads. Flow at .600 means nothing with a .520 cam. What do they flow at that lift?
metcoll
Speed pro 2355 pistons 84cc heads..original flow ootb was 262@600 and after porting 282
metcoll
Sorry meant just a stage one port job
2355 is a decent budget piston. Depending on the headgasket used and how much your block was decked, 9.5:1 is most likely correct. Having aluminum heads makes it "act" like an 8:1, then we need to actually calculate your dynamic compression but need the cam card to calculate that. But essentially i can estimate that engine will be a 6.5 or 7:1 DYNAMIC compression package based on what we know about the cam. That said, the 1 7/8 is the largest i would run, 1 3/4 would not hurt it as the cam will not run high enough to benefit from the larger tubes. Imo anyway.
Challenger340
IMO, this engine will be well into the downside of it's power curve past 5,500 rpm, 1 7/8" headers are plenty.
Only wimps wear Bowties !
metcoll
actually on chassis dyno was still pulling at 5700 rpm, but we shut it down
If it was still climbing, then why shut it down at a low rpm like that?
metcoll
Limited dyno time and really didn't think it would keep on pulling past that..dyno sheet has been posted in earlier threads
