383 lifter noise
Started by euroZ06, May 14, 2018, 05:46:38 PM
euroZ06
Hi,
So during my recent diff swap i had to jack up the rear of the car, and the car sat like that for about 2 weeks. I put everything back, and went for a drive, and this really loud ticking sound came on (almost like a clock ticking, but loud).
Feels like a lifter that is stuck?? Should i add anything to the engine to get it unstock?
Engine has 1500 miles on it or so.
68 charger, 383, 727, 3.55
lukedukem
Are you sure it's a lifter. Do you have headers.
I thought I had the same issue, but it was the header on driver side leaking
Luke
1969 Charger XP29F9B226768
1981 CJ7 I6 258ci
2016 F150, 5.0, FX4, CC
68 RT
I had a loud ticking one time and it was the fuel pump. Also as stated above exhaust leak.
ODZKing
I think this stuff is amazing. Restore, quiets the engine, it's fantastic. Kept my 4 cyl on my old LeBaron running to 210,000 miles and died not due to engine failure!
https://www.restoreusa.com/index.php
Or you could try some break in oil, I am partial to the Lucas products. I think they work well.
https://shop.advanceautoparts.com/p/lucas-oil-products-engine-break-in-oil-additive-tb-zinc-plus-16-oz-10063/7660006-P
With only 1500 miles on it it would be a little early to try transmission fluid in the oil but that would another suggestion. Quiets lifters.
If it only has 1500 miles on it, there should be a warranty. Best to get your money back from the engine builder.
