Garage gift
Started by Draco, December 19, 2017, 02:58:02 PM
Draco
   My garage has been asking for this for Christmas.
green69rt
You're going to need some serious power to run that puppy!!!  What's it take?
Draco
birdsandbees
Depending on the quality of motor it's only going to draw between 20 and 25 amps on continuous run. If your wiring run is short #10 and a 30 amp breaker will work fine. Longer run #8 and 40 amp. What's the amp rating on the motor plate?
Nice compressor for spraying.. it should keep up. Media blasting is the hardest on them, I can keep my 5HP running steady using my big cabinet.
1970 'Bird RM23UOA170163
1969 'Bee WM21H9A230241
1964 Dodge 440 62422504487
Draco
   23 amps running, I am going to run #8 wire just because I have the wire already on a 40 amp breaker, it is a short run. Also have a second 80 gal. tank to add capacity.
Mytur Binsdirti
Nice! I bought a compressor as well last year...
Draco
