Psi of fuel pump
Started by BrugeeRT, December 12, 2017, 10:14:21 PM
BrugeeRT
First technical question as a new member.  I just put in a new fuel pump and noticed the psi is rated at 5.5 and the pressure guage is showing 5.  I thought the range is 6-7.5 Psi?  How much of a difference does this make?  I have a 440 and it runs off a little gas down the carb but not from a key turn.  My next step is doing a carburetor rebuild but I'm wondering how much 1-1.5 psi matters.  Any input is appreciated.
Mark
cdr
it should run with 5.5 psi, something in the carb is plugged up.
randy73
Did you check your filter?
If you are checking after the filter, it might be partially blocked and at what RPM did you check?
If the car is idling low then spec, that would account for it also and the 5.5 is the rating and will not flow at that all the time.
BrugeeRT
Thanks for the response.  It's a brand new fuel/vapor filter and the guage was after it.  I was having the issue before I put it on.  Not sure about the RPMs since I was just trying to get a pressure reading before it does but would have been a good idea though.  Hope a good carb cleaning/rebuild will do the trick.
Mark
BSB67
Quote from: BrugeeRT on December 12, 2017, 10:14:21 PM
I'm not sure what you are saying here.
5 psi is plenty good enough and is not part of what ever problem you are trying to fix.
11.68 @ 120.2 mph
