Exhaust line up
Started by will, December 01, 2017, 10:53:14 AM
will
If i were to swap a 383 for a 440, would the exhaust line up or will i have to tweek the system? I'm just trying to figure out if i'm going to have to buy more stuff. This is with shorty headers.
BLK 68 R/T
Probably will require some sort of work to the headpipes where they connect to the headers, might have to lengthen them some since you are going to a RB engine which will raise the exhaust port locations in the engine bay.
BSB67
Wider too.  If the head pipes have an H pipe welded in now, it will take some work to the point you might consider new
11.68 @ 120.2 mph
will
I really don't want to replace the exhaust if i can, but if i have to i guess i have to. I guess tti is getting some scratch after Christmas.
