FelPro 1215 gasket
Started by Silver R/T, April 28, 2006, 04:35:50 PM
Silver R/T
Does it have 4 gaskets, so 2 go under valley pan and 2 go over it under intake manifold?
2001 Ram 2500 CTD
1993 Mazda MX-3 GS SE
1995 Ford Cobra SVT#2722
yes it does come with 4 paper gaskets
it comes with 4 gaskets , I onl;y ever use 2 though , between the pan & heads to seal the oil / lifter valley , most of the time you won`t even get the intake back on with all 4 gaskets in there
jackel440
I too saw that these come with the 4 gaskets in a catalog ,but why?,when the factory didn't use them.why not just put some gasket sealer on both sides of the valley pan and bolt it together.I have done this in the past and had no problems.
I just wondered why they include them? :icon_smile_question:
Silver R/T
for better heat insulation imo
2001 Ram 2500 CTD
Because of the use of aftermarket aluminum intakes and the fact that a lot of 35+ year old heads & blocks might have been milled
GreenMachine
Quote from: Just 6T9_CHGR.... on April 30, 2006, 05:18:54 PM
   Yes, they make great shims, use however many you need to line up the boltholes.
jackel440
I never even thought about milled heads and pooor fitting intakes and such Duh!!!
694spdRT
I am trying to visualize this in my head but, wouldn't using paper gaskets on milled heads and blocks make it worse? I had to have the intake milled on the old 383 in the '68 to get it to fit right.  :scratchchin:
I does get confusing because the original head gaskets were steel shims and most go with thicker composite ones now too.
1968 Charger 383 auto
1969 Charger R/T 440 4 speed
1970 Charger 500 440 auto
1972 Challenger 318
1978 Ramcharger 360 auto
beenaround
according to an old direct connection book i have these gaskets were to be used on 6 pack cars that were burning oil.the vacuum from the intake would suck oil from under the valley pan.the root cause was as others here have guessed was poorly machined intakes.i seem to remember that early 70 6 packs came with the aluminum intake,but many of them were such a poor fit that they were replaced with the cast iron version.this book was published in 1977 but I'm not sure when this infomation was first published.they also listed the factory part# for the gaskets.to sum this up i think some engineer came up with these gaskets so chrysler wouldn't have to replace poorly machined intakes under warranty.
Yes , using a paper gasket with milled heads or block makes it worse
Big Sugar
Good Topic ! I used a gasket between the head and Valley pan and sealant between the intake and pan,
It all went together with no problems ( Running Aluminum 6 pack Edelbrock ) Although I notice quite a bit more Heat "Tinking" than before (Used sealant only no gaskets) The "Tinking" starts very quickly even before the Engine shows a temperature reading ? Could it be the manifold is too tight ? or is it just seating in ?
The Manifold shouldn't require retorquing should it ?
[img]<table border="0" cellpadding="0" style="border-collapse: collapse" width="182" id="table1" height="202" bordercolorlight="#ECEBF1" bordercolordark="#E9DFD1" b
I alsways retorque the intakes as a habit , they are virtually always loose
Big Sugar
What do you Torque down to ? I torqued them to 50 ftlbs.
Quote from: Big Sugar on May 14, 2006, 10:53:07 AM
That's too much Ron ; 25-30 ftlbs is plenty.
Big Sugar
Could that be the reason for all the " Tinking " ?
66FBCharger
I received my Fel Pro1215 gaskets the other day. I am planning on installing it in the next few weeks. I am using the stock cast iron intake. Do I need to use any of the paper gaskets? If so, what  is the best adhesive to use to glue the paper gasket to the metal valley pan? If only one gasket is needed, should I put it on the intake side or the head side?
'69 Charger R/T 440 4 speed T5, '70 Road Runner 440+6 4 speed, '73 'Cuda 340 4 speed, '66 Charger 383 Auto
SOLD!:'69 Charger R/T S.E. 440 4 speed 3.54 Dana rolling body
I have always just used the valley pan with no issues.  The single time I did try to use the paper ones the intake would not install correctly.
66FBCharger
Thats what I always did and never had an issue. In fact, I don't remember ever getting paper gaskets with the valley pan.
The last few times I bought one it came that way but they never used to.
Quote from: 66FBCharger on April 17, 2014, 07:07:31 AM
Wow, this is an old thread !  :icon_smile_big:
I use Permatex Ultra Copper high temp RTV on both sides of the valley pan around the ports and put a bead on the end rails with a little dab in the corners of the end rails. Let it set-up over night and torque down in the morning. No paper gaskets  ;)
Yes, I have used the sealer as well.  That Permatex copper is fantastic stuff.
66FBCharger
Quote from: firefighter3931 on April 21, 2014, 08:42:40 AM
Ron,
Just so I don't misunderstand, you put the copper RTV on the valley pan and assembly the pan and intake. I'm assuming you put all the bolts in hand tight then the next day you torque the bolts?
Quote from: 66FBCharger on April 23, 2014, 02:24:22 PM
Ron,
Correct, the idea is to just snug the intake manifold down. If you tighten it too much you will push the rtv out before it has time to cure.  ;)
