933 oil pan 440
Started by John Milner, June 06, 2017, 11:41:50 PM
John Milner
Does anyone know if the stock oil pan that came on my 77 440 will work with my 68 Charger? It is a 933 pan. I know this is not the correct pan but I would like to use it if it will work.
GreenMachine
http://www.440source.com/oilpans.htm
Looks like it's from a C body, should work just fine.
cdr
some c body pans hit the center link, the pan is thicker in that area.
funknut
Quote from: cdr on June 07, 2017, 06:32:09 PM
This matches my experience as well. My 68 came with a 699 pan that hit the center link.
John Milner
Thanks for the replies everyone.  At first glance it sure looks like this 933 pan will fit just fine.  I already have it, along with the oil pickup tube clean and was wanting to use both parts if I could.  I just would like to make sure it is right before dropping the engine in.
