Freeze plug ??
Started by randy73, May 04, 2017, 12:24:33 PM
randy73
Does it matter if I get brass, steel or ?? freeze plugs or all they all about the same?
Note: I live in Florida
BSB67
11.68 @ 120.2 mph
XH29N0G
Or maybe it protects us.
you can use either one, if yours is leaking now, it's probably a steel one from the factory.
Brass won't rust through, your call as to what to use
Mopar Nut
Brass, unless you want to paint them, then go with stainless steel.
randy73
Thanks, mine are not leaking, I am going to rebuild the engine and want to replace them.
