trunk pan 2 piece
Started by 70 sublime, January 22, 2017, 12:37:37 PM
70 sublime
Not sure what to do
I am putting in the 2 piece floor but not sure if I want to go all the way up to the factory seam
Has anybody had any luck changing the full pan and then weld in the seam up under the parcel shelf and smooth it off to hide it ?
I am thinking about cutting it off just as it starts to go up and over rear axel so I can reach everything from the trunk lid side
Ryan.C
That is exactly what I did. Right in the middle of the spare tire hold down bracket is where I cut my trunk floor. I just cut the hold down bracket off, made my line and cut the trunk out. Butt welded the new to the old, ground it down smooth and used fiberglass filler to dress it up. looks great now. Looking back on it, it would have been just as easy (if not easier) to install the entire pan instead of cutting it short.  :Twocents:
There are few problems in life that cannot be solved with C-4.
hemi-hampton
I'd go all the way with it. Then the seam easily hides with seam sealer.  :Twocents: :shruggy: LEON.
tsmithae
charger_fan_4ever
The AMD 1 piece trunk floor was one the best fitting pieces of all their metal on my 70. Fit like a glove, no finish work either.
grant52
I agree . I went ahead and replaced the entire trunk floor with the AMD piece. It fit great with little effort.
SmashingPunkFan
https://youtu.be/qV15EMZk_jo
I did the 2 piece last summer. I was pretty happy with removing all the old
Tonight I'm Burning Star IV.
Projects:
1970 Dodge Charger SE (Main Project)
1973 Dodge Charger 400 cid. (Work in progress)
1988 Mustang 2.3 liter 4 cyl.
Looking for Seat tracks for bucket seats.
70 sublime
Quote from: SmashingPunkFan on January 27, 2017, 02:18:38 PM
How did you fill in the seam on the floor when you were done or did you just run a bead of seam sealer ?
SmashingPunkFan
Quote from: 70 sublime on January 27, 2017, 04:03:36 PM
Plug welds. Got em in tight. I haven't added seam sealer yet, but plan to there, and on the floors I'm currently replacing.
Projects:
Canadian1968
I did mine . 2 piece. Went all the way up. Little bit of tight fit to get up there but really, it's not that bad. And as someone else mentioned it's probably easier then cutting and all the body work to hide the new seam . Unless you don't care  :shruggy:
grant52
Test picture using image resizer
grant52
Yay! Image resizer works!! :cheers:
