Radiator Re-core Cost
Started by CRW-FK5, January 17, 2017, 07:36:02 PM
CRW-FK5
I am going to start getting some estimates on re-coring my 26" (956) radiator and was wondering what I should be expecting to pay for this?  Top, bottom, sides are in excellent condition.
Is it recommended to go with a 4 row or stay with 3 row?
smithenhiven
You're probably looking between $350- $500 for the recore job.  As for the number of rows, I've always heard more is better, can't see how 4 over 3 would hurt, I'm sure the rad shop that does the recore will advise you right.
70B5Cuda
I spent $475 to recore the radiator in my survivor 69 Charger. It hurt, but what are you gonna do?
1968 Roadrunner-6.1L, 6 speed, 3.91 Getrag, IRS
1968 Charger- 6.1L, TR-6060, 9"
1968 Charger in RR1 "Ribeye"
1969 Charger in EW1 "S'more"
1969 Charger Survivor-R6, 383, 727.....WRECKED
1970 Barracuda-6.1L, 6 speed, 4.10 S60
68moparbob
Mine was done by a business acquaintance at cost at $350.00.  So, list price would have been around $450.00 +.
I was quoted $500+ for my 22" rad out of my 66....I went with aftermarket
41husk
Glen Ray did mine it was $700 and I would recomend them to all.  I am very happy with it :cheers:
1970 Plymouth Duster FM3
1974 Dodge Dart /6/904
alfaitalia
That a lot of cash....normally things are cheaper in the US!!..... I looked into it here (UK). Classic car guys getting ripped of again. To recore the radiator in my Merc, for example £112 (about $137), not that I would...just buy another but I wanted to compare. To recore the old (possibly original??) one in my 69 ...£400 (about $490!)....even though its the same guy using the same tools and same cost material. He said the reason why was that if he broke it, it would cost a lot more to source me another original spec one!!! WHAT! So I'm paying more in case you break it. I suggested he charged me £112....and I would pay the £400 if he broke it....No go!!
Wont be going either way now.....gonna need a much BIGGER one for my plans!!
M5Ivan
Since mine wasn't original to the car, I went aftermarket with a 26" repro that matched perfectly for $350. It solved my cooling issue and looks stock.
68 RT
I would say 3-500$ Going to a 4 core your tanks have to be wide enough to take the extra core, also if it does make sure the fan you are using is not to close to the radiator.
darbgnik
Quote from: M5Ivan on January 18, 2017, 11:54:17 AM
Where do you get a repro for $350???
Brad
M5Ivan
Quote from: darbgnik on January 18, 2017, 02:44:29 PM
Year One. I bought the one without the numbers stamped on the top, so I guess it's not a true "reproduction" although it looks exactly like the one it replaced (with the exception of the numbers). They also sell one's with the numbers on the top, but they are out of my budget!
Mopar Nut
Quote from: M5Ivan on January 18, 2017, 03:07:32 PM
Did it come in a U.S. Radiator box, I bought one from YO, turned out to be a POS U.S. Radiator.
alfaitalia
....the wrongly clocked caps on those always give them away as repro though...even to an amateur like me...don't know why they do that!
M5Ivan
Quote from: Mopar Nut on January 18, 2017, 03:25:20 PM
Don't remember the box, but it does have the offset cap. Knock on wood  ;D
darbgnik
Hey thanks! I didn't know they were out there in that price range. I prefer the factory look over aluminum, and repro-ish is fine for my non numbers 318 Charger 500 with a 440 in it  ;)
Mine is still holding, but it's nice to know of options when the time comes.
Brad
dual fours
Quote from: alfaitalia on January 18, 2017, 06:01:48 PM
And I thought the owners just left the caps loose :slap: now I see.
1970 Dodge Charger SE, 383 Magnum, dual fours, Winter's shifter and racing transmission.
26 END
J25 L31 M21 M31 N85 R22
VX1 AO1 A31 A47 C16 C55
FK5 CRXA TX9 A15
E63 D32 XP29 NOG
ODZKing
I used a place in Rochester , NY. I am only 90 minutes away so I didn't have to ship. Great job!
That was 2011, a very good chance it has gone up 6 plus years later.
CRW-FK5
Quote from: ODZKing on January 19, 2017, 10:53:32 AM
That looks like a very fair deal, granted it is over 5 years ago as you stated.  I've got a phone estimate locally here (Indiana) at between $400 and $500, hopefully when he sees it he will lean towards the $400.  Maybe if I say it's for a New Yorker instead of an R/T Charger I may get a break too (lol).  Thanks.
Mopar Nut
Quote from: M5Ivan on January 18, 2017, 08:14:32 PM
The reason I asked was I bought one through YO that was made by U.S. Radiator. It leaked on day one, had solder covering the tubes. Called YO, they suggested I call U.S. Radiator, they said "too bad so sad". YO paid $200 to have the radiator fixed local here.
P.S, my cap is offset like that too.
dual fours
To re-core my original 26" and I still have the old core. Old school shop.
26 END
FK5 CRXA TX9 A15
E63 D32 XP29 NOG
1970 RT/SE
Glen Ray did a really nice job on mine and would use them again.
Is this a show car? If not, buy a 2 row aluminum dual pass cross flow for about 200 bucks shipped. A 22 inch aluminum of the above description Will outperform a brass 4 row 26" downflow drastically.
I had my original 69 440 Auto with A/C "055"  converted from a 2 row recored to a 3 row using a high efficiency core about 10 years ago...cost me well over $500
CRW-FK5
Quote from: c00nhunterjoe on February 26, 2017, 11:35:48 AM
Need to retain the original look.
Quote from: CRW-FK5 on February 26, 2017, 03:34:54 PM
Then i would reccomend an aluminum downflow and paint it black. Will still be cheaper and cool better and fit the "origonal look"
