Real HP numbers
Started by Bad B-rad, January 12, 2017, 05:55:58 PM
Bad B-rad
I just got done reading some old threads and one shocked me. I was not around when our cars were new, but have always read that the 426 Hemi and 340 for sure were putting out more real world horse power then the factory rating, due mostly to insurance. Well REB  said that the speed channel did a engine dyno test and rebuilt the engines to stock specs and got 820hp and 760tq from the 426 Hemi. That can't be true. Was that the RACE Hemi that they rebuilt and tested?
If the stock ratting of 425hp and 490 torque is wrong what is real number on the 426 street hemi,and the  LA 340?
Also on the same thread it said that car and driver 1/4 tests had the 440 six pack(in the 69  Roadrunner 12.91@111mph) beating the 426 Hemi (13.4@107mph 1970 Roadrunner)in the 1/4 mile.  Is this also true, and was that because the 69 RR was stick vs the 70RR Hemi's auto? Both had 4.10 rears.
alfaitalia
Experts will be along in a moment but I well say that a laughed out loud at the 820 horse power.......if it was anything like true those quarters would be way faster.
Bad B-rad
That's exactly what I said!!!!If it was a true 820 then its 1/4 mile would be lower.(unless it is smoking the skinny tires the whole 1320!!!!)
crj1968
820...no way.
I always remember reading  the 426 was around 470hp, and a 340 close to 300hp
...and the slant six pushes something like 1200
Bad B-rad
Is that Hp number for slant six net or gross readings?
In that same thread is says the 4bbl 383 is really putting out 280hp.
So numbers are all over the place. What to believe?
I don't believe any numbers until I can see proof. But whatever the numbers, they are sure fun engines to have at your disposal!
I always heard the 440 was quicker in the 1/4 but the 426 would soon catch up and leave the 440 behind in top end given a bit more room to travel.
Bad B-rad
I have had a ton of fun in my 383's over the years.
And I have also been told that by friends of mine that had both engines in cars in the 70's and early 80's. But they always said it was on the street the 440 was better it was the track were the Hemi was able to shine.
I would just be very interested to read or watch the results of the engines built to factory specs  putting out the real life numbers.
I would also like to see a comparison of 383/440/426 Hemi vs 5.7/6.1/6.4 Hemi in 1/4 mile with everything being equal. Same car, same weight, same transmission, same tires and so on.  The older cars no mater what the engines were putting out were at a disadvantage in power loss through the drivetrain and the tires vs modern MOPAR.
crj1968
The GLHS Omni pretty much kills them all in the 1/4 mile.
Bad B-rad
A stock GLH Omni? beats a new 6.4 SRT8 in the 1/4?
I always wanted to turn a rampage into a drag car. Turn it into RWD and put a v10 in the bed of it for power.
Maybe an Omni should be the test body for slapping all the engines in to have a 1/4 mile shoot out.
The published numbers back then were probably correct for the rpm they rated them at. IOW, suppose the Hemi did have 425 HP at 5000 rpm but had a higher HP above 5000 rpm.
Kern Dog
The Mopar Performance 426 crate hemi was rated at 465HP. This was a crate engine built to stock 426 specs with slightly less compression.
Bad B-rad
Quote from: John_Kunkel on January 13, 2017, 02:32:45 PM
Ok so your saying that for the 426 Hemi they may say 425hp@4500rpm and 490tq@3900rpm,BUT those are NOT peak numbers as you would normally expect.
That yeah it was 425@4500rpm but it was still climbing and may be 500hp@5400rpm and 520hp@6000rpm and so on. And for what ever reason, insurance,or what not they just picked 425hp.
Does any one know of dyno tests done on dead on stock spec engines engines?
Quote from: Kern Dog on January 13, 2017, 02:45:06 PM
I am mainly wanting to see 426 Hemi, the 440,Magnum and 6bbl,383 Magnum and the 3406bbl. The 426Hemi and 340 six pack,are the two that I read about the most,that have the reputation for being under rated  by the factory.
I thought the heads,intake(one 4bbl carb vs 2X4bbls)and exhaust manifolds were different.(org cast iron manifolds vs the crate used headers)
Now I don't know any of that for a fact, I thought I read it once,as they were explaining the things that were not the same.
But even the crate engine isn't  820hp!
500Jon
Hi Folks,
I can believe quite easily that a trick 340 would make 400 horses back the the day!
Everyone has got a 400 horse 318's now, if you believe all the magazine articles... :slap:
800 horses for a 60's 426 hemi is a tall order indeed!
Think the guys running the Wingcars were working on 600hp in 1970.
If 800hp was 'on tap' then the Aerocars would never have been built.
The 69 C500 would have trounced the opposition with that much HP.
800hp smallblocks are very common in Nascar now, its 50 years on, you would expect that! :coolgleamA:
IF A JOB's WORTH DOING, ITS WORTH DOING WELL, RIP DAD.
4-SPEED, 1969 Charger-500 is the most Coolio car in the World!
The race hemi was not what you bought at the dealer. I can see 700- 800 hp in the nascar engines, as they were nowhere near stock engines. The nhra stock and superstock classes today are over those numbers. The wedge motors cant touch them.
odcics2
A Nascar spec engine with 12.5 to 1 compression, a Racer Brown STX-24 cam with a 950 Dominator would put out an HONEST 575 HP.  That's what it took to get Baker over 200 in the #88 Daytona. This info is per Larry Rathgeb.
:Twocents:
Bad B-rad
I understand getting those numbers on "worked or hot rod engines"I was curious about the numbers the engine put out as the car was delivered. You know bone stock, from the dealer to the dyno. I just read an article and they rebuilt a 383 to factory specs for a 383 Magnum the only difference being their test engine had 9.2to 1 compression vs factory 10 to 1. It had the stock cast iron intake and HP exhaust manifolds and stock carb. It churned out 335.2 hp, they tuned the stock carb a bit and tweeked the timing and got 338hp@5000rpm and 392torque at 3600rpm. So basically it is right as advertised.
The two Mopar engines I always read about having underrated HP numbers from the factory are the 426 Hemi and 340 Wedge, so those were the ones I was wondering about.
The article in which they rebuilt the 383 was from Hot Rod mag, Sept 1, 2002 some one here gave me the link.
Bad B-rad
Wow that was cool, there is also one video called  1970 stock 426 Hemi dyno. And I think the video says Mikes 1970 stock Hemi. That one is good. It was 452@5500rpm and 490torque@4000rpm. That's very close to factory rating!!!! What surprised the hell out of me was the torque that this thing was putting down the dyno results start at 3300rpm and its putting out 465ft lbs of torque. and it is hit's peak at 4K and even when it starts to come down it never "falls off" it comes down slow. So basically from 3300rpm till 5600rpm (what the dyno rpm has listed)it is pumping out over 420 ft lbs of torque. That's just awesome.
I guess the number Chrysler put out was right on the money about the 426 Hemi. People must have just been so impressed with the "Torque curve" and how fast this engine moved a car down the road, they the couldn't believe that it was "ONLY" putting out 425HP. So they assumed that the factory was lying.
That's just my  :Twocents:
Now we just got to find the 340, and maybe the 440 Magnum or six pack.
The 426Hemi's torque just shocked me, not its peak number, but how it steadily just churns out over 425ft lbs, that's crazy. I would love to see off idle to the 3300rpm,what the dyno didn't show. just to see when that power starts.
There was a nascar article years back where theg interviewed a chrysler nascar engineer. I recall something  to the tune of they tuned the cars to make the hp they needed for a race. Anywhere from 575 to over 600 depending on the day. There was plenty of potential left in them. The drag race guys will show you what a stock hemi is capable of.... just do some youtube searches.
All of the factory numbers in the 60s were "tweaked". As john said, they would choose what rpm to publish their hp numbers to and also rate their dyno numbers without any accessories like power steering pumps alternators and water pumps.
odcics2
....and last for 500 miles!
By 1970 the circle track race hemi was pretty much fully developed to get the most HP and last 500 miles doing it.
Most teams used a qualifying engine that was "tuned up" a bit more!   :2thumbs:
Just to mention if you don't already know it -
The car magazine road tests back in the day were even less reliable than OEM engine horsepower numbers.  From the methods of recording the timing, to the driver skills, to the consistency & condition of the cars they were given . . . it's ALL too far off-the-map to be relevant by modern standards.  And the 1960s tires alone will slow down the takeoffs.  You could probably do better with cheapo tires from Walmart now.
Bad B-rad
Quote from: tan top on January 15, 2017, 11:53:48 AM
https://www.youtube.com/watch?v=8JfkpyzlGxw
THANK YOU!!!!!!!!! That was the BEST CAR PORN I have seen in a long time.
6100-6200rpm with duel points,wow and no one would run that now they would be doing electronic ing. That was great, I need a cigarette!(and I don't smoke)
https://youtu.be/4TKfV9Bflt0
The race hemi was much more potent then the nascar hemi.
odcics2
Apples to oranges.  A 1/4 mile ain't much of a test!   Try 500 miles wide open!   :2thumbs:
Same basic 426 engines, just tuned for different applications.  :cheers:
I think the OP should buy a 340, build it stock and put it on a dyno.  :Twocents:
Quote from: odcics2 on January 15, 2017, 09:21:39 PM
The question wasnt which one lasted longer, just are the hp numbers legitimately possible. The nascar guys of the time said 600 hp was the basic limit to run 500 miles at 7000 rpm. The drag hemis were more then capable of running 800 hp back then and are beyond that today.
Bad B-rad
The 426 Hemi and the 340, definitely the 340 six pack in the AAR 'CUDA and Challenger T/A are the two Mopar engine I hear the most about the factory advertised numbers being UNDERRATED. They always say the 340 was underrated and same thing about the 426,that was my original question,ifthe factory numbers were correct or underrated as is almost stated.
I only build big blocks  :nana:
ws23rt
It has been about 47 years since the 426 Hemi was last offered to the public in a car.
At some point we might just start calling it "old"  :slap:
We can move our ass in a car these days like the hottest cars did in 1970 and it is considered just a device for transport.
The 426 is a great part of mopar history-- and today it is just that.  Those of us that like to play with old cars will never stop liking them.  I am on of those.
I had a Hemi RR for many years and only felt its full power a couple of times. The car was a mess at 150mph.  --Do not try this at home with that body style-- :slap:
I have a hellcat challenger now and have yet to see 700 HP on the guage  (I have seen 600hp). :icon_smile_wink:
What I like to see these days at car shows are the real deal original hemi cars.  A clone car with a hemi should be on the street doing what they were made for. Reliving the past.
A12 Superbee
Quote from: Bad B-rad on January 12, 2017, 05:55:58 PM
Its a well known fact A12 cars were faster than Hemi's down the 1/4 mile.
A12 Dodge Superbee Coupe 4 speed Car number 157 in the A12 Registry.
XBGT Ford Falcon sedan, same model as Max drives in The Roadwarrior, the yellow car he starts off in.
WANT: Triple black 68 or 70 Charger!
Bad B-rad
Quote from: ws23rt on January 15, 2017, 11:18:29 PM
:2thumbs: :2thumbs: :2thumbs: :2thumbs:
1974dodgecharger
A Honda is faster than a stock B body with a HEMI back in the day  :icon_smile_big: in the 1/4 mile
Bad B-rad
That's why I put NOS on my 383,and why I posted the questions about 383 or 400 compression ratio in the engine section here. Because once a Honda almost got me at the track,so I put on a 75hp shot. "Just in case"
The Honda has more gears,give me a 383 and same gears as a Honda and he will never touch me.
Mytur Binsdirti
Quote from: 1974dodgecharger on January 16, 2017, 06:16:53 AM
Sadly (or not so sadly), your basic V6 econobox today has more power than a stock small block or 383 of yesterday.
Quote from: Bad B-rad on January 16, 2017, 06:57:34 AM
What does a 5 speed trans have to do with it? 1 thru 4 are the same and a 4 speed charger. A 4 speed auto honda is the same as a 727. You are not tagging overdrive at the drag strip.
Bad B-rad
[/quote]
A stock 727 has some wide gears,that two to three gears are far apart. and I still have to drive my Charger home from the track, so 4.10 on the highway at 75mph for 1 and a half hrs really suck. If MY Charger was a drag only car then ok I can run 4.30's and the Honda never gets me.
Give me five gears, so I can run a numerically higher, called lower rear end gear, and that way my gears aren't so far apart, I can stay in the power band longer(closer ratio)
So I may not be tagging OD. But OD lets me run deeper gears and still drive the car home not trailer it.
1974dodgecharger
Quote from: c00nhunterjoe on January 16, 2017, 04:30:51 PM
you be surprised how many people more gears the better at the track even modern mopar folks (young ones inexperienced) claim 8 speeds is good for the 1/4 mile runs....claming they run through al 8.
birdsandbees
Yah  :icon_smile_big: Never even used 4th in my 'Bee in the 1/4. 2 shifts off the lights was enough in 13 seconds!  :hah:
1970 'Bird RM23UOA170163
1969 'Bee WM21H9A230241
1964 Dodge 440 62422504487
We run 2 gears in one of the race cars..... it doesnt get much further apart then that.
The tremec 5 speed conversions you reference are not meant to race. I cannot even begin to tell you how many i broke over the years speed shifting them.
Going from 4.10s to 4.30s will not be noticable at all. I ran 30s in my car for years and on a 28" tire it saw limited highway use. I did make several 200 mile trips up into the mountains via the interstate with it. She would hold 70 with no problem and get about 5 mpg doing it. The bigger problem is you think putting more gear in it will make it faster. It will not.
Kern Dog
What Honda?
Your words are not specific enough. Might as well say....My car is so fast, no 'vette can keep up with it. The "vette" being a CHEvette.
Modern Hondas & stuff can be fast on the track but they don't feel faster.  The low/midrange torque isn't there.  And the badass sound of a hot V8 has a big psychological effect too.
Kern Dog
Hell yeah it does.
2 years ago the wife and I ordered a 2015 Challenger R/T. 3 weeks after we took delivery, I had to get it to a shop to do something about the QUIET ! Holy crap these new cars are quiet. I had them remove the mufflers and weld in straight pipes. The cars come with twin catalytic converters, mufflers and resonators. Now ours can be heard at idle and part throttle. Before, it sounded like a Tesla.
In my 2007 Ram, I added a Cold Air Kit and a Flowmaster muffler. The intake roar is annoying though. It reminds me of Quadrajet equipped GM cars with the air cleaner lid flipped over.
MMMMMMMWWWWWWAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA!!
Quote from: Kern Dog on January 17, 2017, 04:30:51 AM
Hell yeah it does.
https://youtu.be/lPINTtGZAqo
