Value
Started by RealWing, November 18, 2016, 05:43:27 PM
RealWing
Looking for some thoughts on the approx value of this Superbird as-is. Body is in very good condition as well as the floor pans and frame. Only rust visible is a narrow bottom strip behind rear wheels. Car has been painted twice in EK2. 440-4bbl Engine is original but not the 727 tranny or the carburetor. The whole interior is very moldy, since car has been sitting for some time in an unheated garage. Front bucket seats have been recovered, rears are original. Body code plate and a partial Broadcast sheet are there. Car originally came with 14" Magnum 500 wheels & full undercoat.
It will obviously take many $$$$$$ to bring it back plus the cost or finding several missing parts including both jacks, nose trim, 4 wheels and spare , latch tray, bottom nose panel, air cleaner. Strangely someone has removed the wing brackets and the angle brackets that are welded to the trunk floor pan!!  Another odd thing is that it has a column shift steering column in it!!
Jim
1970 Superbird 440-6bbl
1969 Barracuda 340 Formula S
1969 Barracuda convertible  6.1 L Hemi
2015 BMW K1600 GTL
birdsandbees
Many had column shift in them! $8 for a can of Lysol may cure the mold issue...
The trunk brackets and quarter panel "washers" are worth good money.. probably why they're gone.. if it's a real bird!
1970 'Bird RM23UOA170163
1969 'Bee WM21H9A230241
1964 Dodge 440 62422504487
RealWing
Some more photos
2015 BMW K1600 GTL
RealWing
Quote from: birdsandbees on November 18, 2016, 05:46:23 PM
It is a "real bird"
2015 BMW K1600 GTL
RealWing
More photos. 66000 miles on it. Headliner was replaced at some point - the all important rear window interior trim is there!!!!!
2015 BMW K1600 GTL
1970Moparmann
Based on the one that went for $80k on Ebay, this once can't be too far behind it.
RealWing
Quote from: 1970Moparmann on November 18, 2016, 06:07:59 PM
Do you happen to have the link to the Ebay bird?
2015 BMW K1600 GTL
odcics2
skid plate on the engine crossmember...   :scratchchin:
RealWing
Quote from: odcics2 on November 18, 2016, 10:20:32 PM
It was coded as a "79" on the Broadcast Sheet which is p/n 3466479 - 440 crossmember with skid plate.
Just noticed the brace from the K frame to the Rad support is also missing.
2015 BMW K1600 GTL
moparstuart
replacement manual console in an automatic car
RealWing
Quote from: moparstuart on November 19, 2016, 12:30:58 PM
Are you saying that this is a manual shift console????  If so, how can you tell??
Thx
Jim
2015 BMW K1600 GTL
1970Moparmann
It was the one that came from NY or PA?
After a weekend of work, this car can be close to it.
DAY CLONA
Quote from: RealWing on November 19, 2016, 02:20:50 PM
Thx
Jim
That's not a manual transmission console in that bird...
RealWing
So why is there a column shifter tube in the steering column of a console car???????
2015 BMW K1600 GTL
that is the locking lever for the shifter. You cannot turn key to off and lock without the shifter on the console being in park
Mopar John
It looks to me that either someone took all the easy to take off parts and stored them somewhere along the line for safe keeping or
someone just took all the easy to take stuff??
The grille and grille frame, turn signal frames, the turn signal lenses and the windshield pillar deflectors along with all the already mentioned items!
MJ
RealWing
Quote from: A383Wing on November 19, 2016, 07:58:54 PM
You are correct. I had not thought of that.
2015 BMW K1600 GTL
DAY CLONA
Quote from: RealWing on November 18, 2016, 05:43:27 PM
Being a "base model" Superbird, the color being the only desirable option, buckets and floor shift auto are somewhat a plus, and it's current condition, assuming it's not carved in bondo, $75K +/- $5K
The "missing" parts are easily replaced with reproduction items, the restoration, depending on how much is farmed out by a potential buyer, will determine the initial buy in, and max offer
rob-dirt
Quote from: RealWing on November 18, 2016, 06:39:25 PM
No link the one on ebay in new york NEVER SOLD the buyer did not pay ...the guy that ownes that car didnt pass on did he ? ANYWAY  soon you will be able to tell 9 coming auction too many for sale at one place .. my reflect on the prices
https://www.hemmings.com/classifieds/cars-for-sale/plymouth/superbird
FJ5WING
Is it me or does there seem to be A LOT of oxidation on the unpainted metal? Was this car sitting outside or in damp conditions? flood?
wingless now, but still around.
RealWing
Quote from: FJ5WING on November 20, 2016, 12:51:10 PM
There is a lot of oxidation - especially noticeable on the carb and in spots under the car. It has been sitting for several years in an unheated shed (it has a cement floor - which also causes corrosion) and has thus been subjected to humidity changes as the weather changed. has not been in a flood.
2015 BMW K1600 GTL
Redbird
Nice looking car!
With the pictures it is still a wild guess as to value.
It looks as if it needs a complete gut on the interior, steering wheel cracked, no glove box, mold issues. I am going to take the description at face value, needs a check written to Legendary, probably for door panels, the works.
Without being there it is very hard to venture how much bodywork will be needed. Can't really see quarter panel issues, the trunk looks surprisingly good. Is it bubbling underneath or undercoating? From the rust on the exhaust pipes (and other lower body parts), they look gone, is that how other parts of the bottom of the car are?
Needs Latch tray, center under panel, grill frames, trunk braces, parking lights, A pillar trim. All are available reproduction. All can be found in original parts given an infinite amount of time. Original grill frames probably hardest to find, folks don't like the prices on original parts so repo's here. Folks won't pay a reasonable price for an original center under panel either, so they put cheap repos on. Are the diamonds in the back there? Buying repo parts is going to limit the restored desirability and probably never a podium car w/o original parts. Still a very nice car to drive.
The corroded under hood parts are going to add up. All available, just time and money.
Given the general presentation of the car, it probably deserves original parts.
Does the radiator have the right #'s?
I think this car will draw a good amount. A project car that can be restored, how many are there out there for sale? I'm guessing 80K+.
RealWing
Thanks Redbird
We went over the whole body looking for bondo - and only saw some behind the rear wheels along the lower edge of the QP. There might be some small holes in the trunk floor in spots - hard to tell. Other than that - body is excellent. Exhaust needs complete replacement - the rest of the under carriage looks OK.
I agree that the missing parts can be replaced with repro's - but like you said - that ultimately decreases the value. ( The A pillar s/s deflectors are there - hard to see in photo)
Rad is original - even looks like the original foam seal between the top of the rad and the rad support is there!!!! The diamond plates are there.
Jim
2015 BMW K1600 GTL
Beep Beep Dave
If I were buying I would think $60-$65k would be where I would feel comfortable. I think there would be a few buyers in that area. The car really needs a total resto and has parts missing. The ones that are present don't appear to be in the best of shape.
Dave
'69-1/2 SIXPACK/SIXBBL REGISTRY On-Line Registry for the Lift Off Hood cars!!!
Maple Leaf Mopars your Canadian Mopar site.
1970 Charger R/T
RealWing
Quote from: Beep Beep Dave on November 21, 2016, 06:46:17 PM
Dave
2015 BMW K1600 GTL
