sounds like washers
Started by tiki, October 18, 2016, 04:38:05 PM
tiki
just got the charger on the road and while going over bumps it sounds like a handfull of washers in the front end (maybe in the wheel area)  i checked double checked wtf?  :flame:
shorty442
...loose or missing sway bar bracket bolts?
lukedukem
Loose center cap. Do your rims have center caps.
Does it keep doing it if you hit the brakes. My jeep had a rattle and when I hit the brakes it went away.
Luke
1969 Charger XP29F9B226768
1981 CJ7 I6 258ci
2016 F150, 5.0, FX4, CC
tiki
new sway bar and center caps are good thinking maybe inner wheel bearings :flame:
Mytur Binsdirti
Welcome to the world of nearly 50 year old Dodges.
ITSA426
Bronzedodge
I found my caliper bracket loose when I developed a rattle a few weeks ago.  My fault - had done a mad thrash changing a lower control arm bushing right before Carlisle.   ::)   It had a metallic rattle sound.  Only about 1 turn loose.
Mopar forever!
tiki
always something to do thanks for the input ill keep searching... :popcrn:
A12 Superbee
Pebbles inside the centre caps.  ;)
I did this to a mate once, had him scratching his head for days! :flame:
A12 Dodge Superbee Coupe 4 speed Car number 157 in the A12 Registry.
XBGT Ford Falcon sedan, same model as Max drives in The Roadwarrior, the yellow car he starts off in.
WANT: Triple black 68 or 70 Charger!
crj1968
Grease cap fell off rattling around in center cap? That was my noise....could hear it when driving past a fence or wall
Kern Dog
Quote from: A12 Superbee on October 19, 2016, 12:02:33 AM
I've done the "rock in a hubcap trick too. Funny stuff.
Also switched positions of the spark plug wires.    :rofl:
alfaitalia
Not noise related but drawing a pencil line around the inside of my mates Ford distributor had him scratching his head for a while!
PlainfieldCharger
Quote from: crj1968 on October 19, 2016, 12:25:13 PM
I also had aftermarket grease cap that came off and was making noise similar to your description.
tiki
i will check the torque specs 52 ft lbs on the strut rod,it feels like the wheel bounces while going over bumps in the road :flame:
Wingnut426
Lower shock bolts loose or upper shock hardware loose or missing? :Twocents:
HEMI Daytona Convertible
72Charger72
I remember some old timer Union guys telling me when they would get peeved they would weld cans of marbles and crap inside frames etc .... :smilielol: :smilielol:
crj1968
Quote from: 72Charger72 on November 02, 2016, 02:03:13 PM
I know a guy that had a washer swinging from a string inside his door.
