Upper door hinge removal
Started by Raindem, July 22, 2016, 12:29:27 PM
Raindem
Hi Guys.  Quick question.  I'm removing the doors and hinges from my '73.   On the upper hinge there are 2 bolts that hold it to the A-pillar, and then some kind of pin that the hinge hangs on.  Is the hinge supposed to slide off that pin?  Mine won't budge but I don't want to apply too much force until I know for sure how it is supposed to come apart.
Curt
E5 Charger
The pin you see is actually a bolt that you remove from inside the car.
Raindem
Thanks.  I saw that in the diagram in the manual but I wasn't sure if it threaded into the hinge or not.  I was secretly hoping the door just slid onto it to make it easier to hang.  No such luck.
