decal removal
Started by boss429kiwi, June 29, 2016, 02:24:26 PM
boss429kiwi
Hi
Has anyone tried to remove the front nose cone decals, from good paint?
Any hints and suggestions.
Gary
NEW ZEALAND (aka Paradise)
1973 De Tomaso Pantera GTS widebody
1970 Superbird, 6pack, 4 speed, Tor-Red, Buckets, restored by Julius
1970 428 Cobra Jet, 4 speed, calypso Coral, white shaker
1970 Boss 429 KK2457, Concours, Calypso Coral (SOLD)
1957 Chevy truck, big rear window, ocean green, STOCK!.....nice!
1RareBird
Medium heat from heat gun slightly ahead of where you're pulling up from, don't get too close and try move from one end to the other. In addition there is an eraser (3M) that works off a drill and will remove the decal without harming the paint. Either method works, good luck.
When I die I want to go like my Grandfather did, quietly in his sleep.  Not screaming like the passengers in his car.
Aero426
Heat gun for the large decals will do the trick.
boss429kiwi
Brock Lee
Quote from: 1RareBird on June 29, 2016, 02:30:40 PM
Those eraser wheels are bad ass! They work great! I particularly find them the best solution for old vinyl that has become brittle and wants to come off in tiny pieces. But they will cut through any vinyl.
I will only add that I prefer them in a high speed tool..
Aero426
Eraser wheel works great for smaller decals.       The nose decals should peel off with some indirect heat very easy.
odcics2
Easier to own a Daytona!    :Twocents:
:smilielol:
A12 Superbee
You need a caramel wheel, they work great, not sure if its called the same thing over there tho as here in Australia.
A12 Dodge Superbee Coupe 4 speed Car number 157 in the A12 Registry.
XBGT Ford Falcon sedan, same model as Max drives in The Roadwarrior, the yellow car he starts off in.
WANT: Triple black 68 or 70 Charger!
