Fender Tag Decoder
Started by JMF, May 17, 2016, 05:16:50 PM
JMF
Is anyone able to decode my fender tag for me ? I did try on one of the decoding sites but a lot of them were not recognised, also the engine code doesn't seem to be on there ? Thanks
birdsandbees
Most decoders should have done that for you. Out of my head...
It's a 383 HP (E63) car.. Automatic (D32).. built June 2nd in 69.
White body (W1).. white top (W1) .. black bench seats (H2X).. black upper door panel (X9)
595 = 3.23:1 suregrip w/11" brakes
926 = 383  + automatic
285266 is your VIN #
1970 'Bird RM23UOA170163
1969 'Bee WM21H9A230241
1964 Dodge 440 62422504487
JMF
Thanks for that , how come the engine code is not on the fender tag ?
birdsandbees
Engine code is on the fender tag.. E63
Fuzzy
Hi All,
My fender tag decoded below missing info ...
Does anyone know what the V1X and A33 stands for ?
What are M31 "Belt Mouldings" ?
Thank's alot
XS29:
Dodge Charger
Special, R/T
2 Door Sports Hardtop
L9B: 440 375HP 1-4BBL 8 CYL
1969
Dodge Main, Hamtramck, MI, USA
360374:   Sequence number
E86:    440 cid 4 barrel V8 (High Performance) 375hp
D21:    4 Speed Manual Transmission
R6:    Red Exterior Color
C6R:    Trim - Charger, Vinyl Bucket Seats, Red
R6:    Red Int. Door Frames
428:    Build Date: April 28
256846:   Order number
A33:    Unknown Top Color
B51:    Power Brakes
C55:    Bucket Seats
G15:    Tinted Windshield
M21:    Roof drip rail moldings
M31:    Belt Moldings
R22:    AM Radio with 8 Track  (10 Watts)
V1X:    Unknown
V88:    Tranverse Stripes, Deleted
26:    26in Radiator
END:    End of Sales Codes
Dream never dies just the Dreamer
JMF
Yes but I mean the H that is on the vin is not on there
Alaskan_TA
It is a Lynch Road tag, so that is normal.
69CoronetRT
Quote from: JMF on May 22, 2016, 07:12:17 AM
The H in the VIN and the E63 sales code only tell you the car received a 383-4bbl. The do not tell you which assembly the car received.
Lynch Road tags coded differently. The good thing about the LR tag is that it tells you EXACTLY which engine assembly came in the car. Other plants do not code the assembly on the tag. In your case, the car received the 926 engine assembly = 383-4bbl 335 horse B body assembly designed to be used with an automatic transmission (93 on the tag indicating the 093 HD transmission).
So the "H" is not on the tag. You have something a lot of folks don't have and that is fender tag acknowledgement of which assembly the car received.
:2thumbs:
Fuzzy
Quote from: Fuzzy on May 21, 2016, 09:25:42 PM
Hi All,
Does anyone know what the V1X and A33 stands for ? Found out the A33 stands for "A33 3.54:1 Dana 60 Track Package (69-71)and the V1X means black vinyl roof
Thank's alot
XS29:
Dodge Charger
Special, R/T
1969
B51:    Power Brakes
C55:    Bucket Seats
M31:    Belt Moldings
V1X:    Unknown
26:    26in Radiator
hemigeno
Those are the exterior stainless mouldings at the base of the door window opening & rear quarter window opening.  They curve up in the back corner of the rear quarter window, to connect with the M21 roof drip rail mouldings.
Looks like you have the balance of the tag decoded pretty much OK.  Nice car & option combo.
