handling help needed
Started by poppa, May 21, 2016, 07:36:45 PM
poppa
Hello all , I (maybe wrong choice) put my car back together with all 'new' stock stuff. I was hoping to get it to handle better and that is not the case. I was thinking about the weld on braces for the lower control arms , anyone seen a difference with this? Also , I remember seeing something somewhere about welding some kind of "gussets" on the k frame , anyone have any info on this?? I am also planning on a Firm Feel power steering box. I have some Goodyear Eagle ST' s P205's on the front always checking tire pressure cuz they always seem low but are ok. They say max load 1443 , if all 4 are rated at that they would be ok for a 4000 lb car , correct? I didn't see an actual 'load rating' , I thought there would be. Any other suggestions would be greatly appreciated.  Thanks for reading this far.
Kern Dog
It is hard for me to concentrate with that picture of the woman up there. The sun shining through the hoo-hah has me thinking of things other than how a car handles...
JR
Post up some more details of your car. Year, pics, specs, etc.
The basic problem is all vintage Mopars were under sprung/dampened, don't have enough caster/camber to take full advantage of modern tires, and had terrible weight distribution for starters. Chassis bracing is always helpful, but that alone won't suddenly fix the handling.
What size Torsion bars/rear springs/sway bar do you have?
adauto
Every little bit helps, but the best improvement overall on my car was a combination of parts. Subframe connecters/level 3 steering box/boxing a-arms/ BIGger T-bars/ shocks/ offset bushings/BIGger sway bar/greasable pins/adjustable strut rods..... if I'd upgrade my ol' BFG's it prolly be much better....  :smilielol:
Never too many! 70 Chally R/T Convert-70 GTX-68-69-74 Charger-68 Dart GTS
http://a-dauto.com/  http://www.facebook.com/pages/A-D-Truck-and-Auto-Parts/67427352555?ref=hl
poppa
Everything is stock size ,T-bars , sway bar , has frame connectors. Shocks can't have 10,000 miles on them. I was thinking about the bigger sway bar. Thanks for the quick replies
adauto-boxing a-arms?
jr-69 ,440 4 spd , originally a 383
kern dog-focus  ;)
myk
Quote from: poppa on May 21, 2016, 10:09:05 PM
kern dog-focus  ;)
Since you're obviously not going for the wanna-be track star setup like my car I can tell that you will be 100% satisfied with a fat front sway bar, a rear sway bar, and quality shocks like the Bilsteins or Hotchkis units.  Your car will handle much better than it did before with just those few pieces added on.  Oh BTW what tires are you running?  If you're using something like BF Goodrich TA's like most muscle car guys do, that also affects handling potential...
lukedukem
Are bfg tires not good to run as far as handling?  What's a good alternative. In size 225/70r15
Luke
1969 Charger XP29F9B226768
1981 CJ7 I6 258ci
2016 F150, 5.0, FX4, CC
poppa
On the front I have Googyear Eagle ST's , P205. They usually look low (on pressure) but are usually at correct pressure. I will be changing tires/wheels after I install my new leaf springs and see if they still "rub" when I hit a good bump.
HPP
You seem to really key in on this and for some reason. This would be one of the last mods ever needed and only if you run a massive front sway bar.
What do you want to accomplish and what do you see as improved handling, what is the budget you want to get there, and how  modern are you willing to go on the rims/tires?
I ask because  if you just want to step up a bit, bigger sway bars might be all you need, but if you want to push it further, than more significant mods are in order. The budget becomes a big part of this as you've recently  dropped  some coin on stock stuff and a large % of that now needs to go to the scrap bin, so you going to be buying new parts all over. Wheels and tires then become the connection to put all this to the road. Your 205s aren't going to hold up to diddly squat in a corner and wheels and tires can be the biggest expense of the whole project.
poppa
Lennard , Yes those are what I was thinking about. Thanks
It appears that Magnum place is out of business???
poppa
HPP , I would go the bolt on route first before a lot of welding happens. Just looking for some opinions/suggestions on what has worked for others. For $20-25 bucks though , if members have had good luck with boxing the LCA's , it seems like a no brainer. I am in no hurry. I have been leaning towards the bigger sway bar , maybe a rear one , the steering box and a steering (maybe the bearing??) support upgrade that I saw somewhere. As I mentioned , tires rims will be switched after I see how the new leafs pan out with the occasional tire rubbing.
Thanks for all the replies so far!
Lennard
Quote from: poppa on May 22, 2016, 08:03:47 AM
You can buy those plates at different places, like mancini racing,  just suspension,  firm feel,  etc.
myk
Quote from: lukedukem on May 22, 2016, 07:41:21 AM
Luke
They're a very hard tire that doesn't have any grip; some people here refer to them as hockey pucks.  I'll probably try something from Nitto next; that's the generic choice for people seeking a budget handing tire.
I've learned that wheels and especially tires are critical.  Even if you made no other changes to suspension a sticky tire will make a difference.  Of course if you're an idiot like me that changed the suspension  but kept the crappy tire then you're SOL...
adauto
kern dog-focus  ;)
Yes, and was easy to do  :yesnod:
JR
Well, I'm chasing the same thing with a 2nd gen, better handling. Here's my thread from my last autocross. I've been installing suspension upgrades gradually, then testing them on the autoX to test the difference.
http://www.dodgecharger.com/forum/index.php/topic,123877.0.html
My car sounds similar to yours. Here's the route I'm going.
17 /18 inch wheels. I don't know how commited to the old 15s you are (alot of Mopar guys are for some reason),  but modern tires in good compounds are invaluable. There is no comparison between a 15inch BFG ta and a 17inch summer tire. It's night and day. More traction, less tire rollover, less understeer, more predictable, night and day difference. There's a reason new vipers don't come with BFG TAs.
Offset UCA bushings or adjustable upper control arms- Caster/camber are your friends with modern rubber. You won't get much of either with stock a arms and bushings. Bias ply tires and manual steering liked 0 camber and negative caster. Modern tires and 80mph highways today are totally opposite. Positive Caster will help the steering feel more planted/solid at speed, and help the wheel return to center. More negative camber will allow the full contact patch of the tires to touch the ground when the body is leaning over in a corner.
Proper front/ rear sway bars. I have a Hellwig 1 3/8th up front and an adjustable 7/8ths bar out back. These alone(with modern 17 inch tires) COMPLETELY changed the way the car behaved. It went from a wallowing, understeering, sloppy pig, to a fun, more responsive, controlled car that can be steered with the throttle.
Proper shocks. There are some blisteins that are pretty popular, they run 400 for all 4. Pricey, yes, but they are important. They're the second half of your suspension, they keep the springs under control after bumps. Without them, the springs would bounce continuously when they hit bumps, breaking your tires contact with the road. Huge difference in quality between parts house cheapies and proper performance shocks.
There's more, but I would start there. The subframe/a arm/chassis bracing will be beneficial, but I wouldn't get hung up on that yet. The stock suspension tuning is so bad, you aren't anywhere near stressing the car bad enough to notice any difference braced/unbraced.
You won't really feel any difference there until you actually make the suspension do its job properly, and start generating grip.
HPP
I'd agree with JR.
Chasing handling can get expensive quick, so lacking a defined budget and looking at simple bolt ons, I'd follow his advice; wheels/tires, shocks, sway bars. If, after that you want more, then we can start getting into incremental improvements.
QuoteThe subframe/a arm/chassis bracing will be beneficial, but I wouldn't get hung up on that yet. The stock suspension tuning is so bad, you aren't anywhere near stressing the car bad enough to notice any difference braced/unbraced.
Chassis bracing matters for the ride quality & the long term condition of the car, as much as for handling.  I would do that first if it was mine.
A 440/4spd can flex the unibody with 7" wide wheels and normal tires.  Unibody stiffness is partially why modern cars feel so "tight" in the fit & finish.  It's not strictly necessary but it's money well spent.
303 Mopar
Quote from: Mike DC (formerly miked) on May 24, 2016, 12:05:49 PM
I installed subframes on my 440 Charger recently and it made a huge difference for overall tightness of the car, door/windows fit better, and less rattles.  Big bang for your buck.
JR
By all means, I support the chassis bracing, but I don't think he should be focused on addition bracing right now. He already has subframe connectors. If he's pursuing better handling, I vote for correcting the wrong spring/shocks/sway bars & tires before prioritizing boxed a arms and torque boxes.
No argument from me on the beneficial effects of stiffening the car, though.
303 Mopar
Quote from: JR on May 24, 2016, 01:31:38 PM
I missed that in his other post - I agree with the above springs, shocks, sway bars and tires first.  I would add a good set of front disc brakes too if you don't have them already.
garner7555
I agree with JR, bigger torsion bars, sway bars, better shocks, and tires.  Try that first, if you want more then move on to tubular control arms, Hotchkis rear springs, and more chassis stiffening.     :2thumbs:
69 Charger 440 resto-mod
A 2 ton car will never handle on a 205 tire. If you want "spirited" cornering, then you will need a 245 up front.
   I had 245/60/15s on the front of mine with all stock suspension components. .1degree toe in, .4 neg camber, 3.5° positive caster and lowered power steering pressure. Handled great through the corners. Autocross- no, spirited street- yes.
   Tubular upper control arms will give you the ability for about 5 degrees of caster, well worth the 300 bucks a pair.  Weld on subframe connectors literally make it a totaly different car alone.
poppa
Thanks for all the suggestions/replies.
JR - Yes I have some trouble with my steering wheel coming back to center. It usually doesn't want to.
fizz
Last weekend first time pushed my newly built car w/us car tool subframe connectors, torque boxes, radiator support reinforcement and fender apron to firewall braces. Hotchkiss upper control arms, front sway bar, nonadjustable fox shocks, and torsion bars. Addco sway bar on the back, 245/17 and 275/18 conti contact tires. Firm feel stage 2 power steering box. Hydroboost brakes w/cordoba disc brake conversion on front and drum rear. Amazing. As good as my kids 2010 ss Camaro. IMO
