Carb advice wanted....
Started by C500, May 17, 2016, 02:37:09 AM
C500
Hi guys,
I'm currently having the original 440 in my '69 rebuilt, and after some input on a good brand/size of carb from those with experience....
Engine has new new JE pistons, 30 thou over, Edelbrock CH4B intake, HP cast iron manifolds, mild cam upgrade Crower HDP271 (thanks Ron!!) gross lift 486/496, 906 stock heads, -10 crank grind, Johnson topline lifters (thanks Bob  :2thumbs: ) 3.23 rear.
This is built as a street cruiser. 750 is the optimal carb size?? Looking for reliability and tunability on a carb. Vacuum secondaries over mechanical (dp)???
Cheers,
Duncan
"An aggressive exterior with power to match was enough to pull in the performance boys-especially when abetted by a pair of pipes blaring out the back, and brawny red-sidewall rubber hitting the pavement."
"........the four speed box changes cogs with the precision of a sharp axe striking soft pine."
myk
Ron would suggest the Proform 750.  I've been thinking about that or the Fitech.  Can't decide...
1974dodgecharger
get fitech fuel injection....
myk
I dunno man.  I like the idea of the Charger being a brutal, yet simple sledgehammer that's picked up a few tricks; but not too many...
68CoronetRT
Fitech all the way. Carbs are so stubborn.
RallyeMike
Injection is nice but I'd rather fix a basic "stubborn" carb on the side of the road than injection.
1969 Charger 500 #232008
1972 Charger, Grand Sport #41
1973 Charger "T/A"
Back N Black
Quote from: RallyeMike on May 17, 2016, 09:05:06 AM
I agree, i have pulled carbs apart on the side of the road and back on the road in 20 min. If the FI fails your on the back of a tow truck.
Not me, that's what tow service and credit cards are for.
stuubi
If yuo're gonna run it on street only and some occasional "signature on the road",i would go with 600-670 vac Carb.You will love the throttle response,easy cold running without choke,and good manners on highway.
700-750 will give you some 15-25hp more but difference in basic driving is to be seen unless,you tune it right or have someone who knows,tune it to you.
Yes the stock Thermo was something 780-800cfm but on primaryside,it was/is equal to 570-650 size carb primaries.
(This opinion comes from my own experience,last late-Summer i tuned 22 cars either Holly,or Edel/Carter carbs.From De Tomaso 414cid to stock -64 Chevy truck.And on raceday,from 14sec bb and sb motors to 500 Pro Stock)
OTB carb is never great or perfect,it takes some tuning to get it right,but many have been in the "it will run"-ballpark.
Both Holly and Ede have been in the need of more or less tuning,
when tuned correctly,they will be about as good as FI...almost.
Response is immediate,no bog or bang,from 30mph to 80mph it will go on tiptoe.And step on it,it will roar on instant and pull as long as the engine can.But it takes some presise tuning with wideband to get it right.Yes,timing need's to be tweaked also..And you will see difference when you floor it from dead stop.Cars that never spinned tire,started to roast them...
Edel is easier to tune,faster to tune but Holly will run exelent if tuned correctly.Allmost 50-65% of cars i have tuned with Holly,power valve need to be changed,acc squirter will be changed and pump cam needs to be replaced.
On Edel,rod's will be swapped and pump need's some tuning.And some jet changes on both carbs..
rpm x cid
----------  equals your carb size.
3456
so let say you run mostly on 800-4500/5000rpm on your 440 motor.So the formula would go:5000x440 divided by 3456 will give you answer 636-This means that in theory,at 5000 rpm,your engine need's only 636cfm to breathe.
Drop the rpm to 4500 and you will get 572.91 =573cfm...
5500rpm and 700cfm.
So,,shoot for 600 to 670 and you will like it.
Yes,,,it will make more TOP power with 750 but,on average from 800-4000 it will kick 750 all day long...
Before i put my Charger to garage to transfom,i swapped 750carter from 383 away,and bought Holly Avenger 570 on it.After some minor tuning(did not have that wideband at that time) it was a blast to drive!No hesitation,and i ran 110mph on highway,and when i floored it,it started to gain speed so...
New 383 is going to be much meaner so it will have bigger carb than 570,but i will run it on dyno with 570 just for fun :D
C500
Thanks for all the responses guys,  :2thumbs: Does anyone here have any first hand experience with FiTech, never heard of them before? Looks like a good system, but personally I like the carb idea.... tuned properly!
Brass
If you have a manual or an auto with more stall, I would go with a mechanical secondary.  Vacuum is probably fine for a cruiser though.
ws23rt
To me a big part of the fun with our old cars is how they were when new.
I get the interest in making these old cars more like what we have grown used to for drivers.--- I feel it too.
When one updates one system in a 46 year old car it only addresses that one system.
As new our chargers ran just fine as they were built in the day and gave many miles with little trouble.
Some in this hobby could care less how the car performs. To them it's all about fit and finish.
For those that want a new world car with an old world skin.  Stevearino of this site has done very well at bringing the two together.
Am I alone in thinking that advice to move to FI is not helpful for questions about carbs??  :Twocents:
birdsandbees
I love my old car because I only ever needed a pocket knife to get it home... Carb all the way for me..
1970 'Bird RM23UOA170163
1969 'Bee WM21H9A230241
1964 Dodge 440 62422504487
A few years ago I went from a slightly modded 750 vac sec Holley (Pro-form main body (dominator style)) to a 800cfm Edelbrock Thunder series carb with electric choke.  Could never get the Holley to lessen the rich, eye burning fuel smell at idle....the lack of a choke was getting annoying on cold weather starts
The eddy worked flawless for me pretty much out of the box....adjusted choke & fuel mixture and that was it...no rod changes etc.
No stumble, no hesitation off idle or when secondaries kick in....eye burning is still there but Id estimate its better by at least 50%...I attribute the rest to the cam overlap.
This is on a fairly mild 440 with 9.3:1 comp and 915 closed chamber heads, stock intake & stock exh manifolds... :Twocents:
ws23rt
Quote from: birdsandbees on May 17, 2016, 07:16:31 PM
:2thumbs:   I like the way they look and the way they drove.  Not to mention all the memories of being able to limp home when needed with a few simple tools as you mentioned.
If for example my new challenger came to a stop on the side of the road.  I would of course open the hood and have a look. :scratchchin:  It's a routine I grew up with. :icon_smile_wink:
The truth is unless steam is coming from under the hood I would have no reason to even lift the hood. :lol: :slap:
XH29N0G
Quote from: Brass on May 17, 2016, 06:37:53 PM
I am thinking the same thing.  If it were me, I would lean toward 750 rather than 650 because I tend to like the idea that it could run a little better up top.  It will be important to set up correctly.  I am using an A/F gauge and like it because it helps me with fine tuning, but I know the old ways of tuning also work.
Or maybe it protects us.
68CoronetRT
Quote from: C500 on May 17, 2016, 03:49:35 PM
Yes, Its about 100x times better than any carb I ever messed with. I love bumping the key and idling at whatever I want it to on the first crank. I love being able to restart the car in any weather condition,regardless of heat soak. It has more power now than ever. I never have to change a jet ever again, do that on the fly. No more stinking clothes at the end of a trip.
Plus the ultimate, happy wife happy life and she can actually enjoy the car now without stinking of raw fuel.
But hey, its not for everyone. :lol:
Brass
Quote from: 68CoronetRT on May 17, 2016, 09:21:54 PM
Just not smelling of fuel all the time would be worth it.
myk
I like the smell of fuel, oil, plastic, vinyl and rubber; the hallmark scents of a muscle car.  I used to put my clothes in the trunk of the Charger so I could enjoy the muscle car scent even when I wasn't driving the Charger.  Hell, if someone marketed this particular scent I would buy it and wear it proudly.
As for carb vs EFI, it's a difficult question for me.  The benefits of EFI are obvious, but the simplicity of a successful carb set up is also appealing.  And hey, it's not as if the Fitech users aren't having any setup/tuning issues either.  Just look around this site or on the intrawebz....
C500
Quote from: myk on May 18, 2016, 03:30:15 AM
Good call... I might try a Fitech unit in a couple of years, but will get running with a new carb for now. Will go the 750 for the top end.
Vacuum secondaries, looking like Proform or Edelbrock are the carb of choice for Mopar users here...  :popcrn:
myk
I've had my Edelbrock 750 for a while now and I am not a fan.  Cruising different Internet boards show that many people feel the same way, calling them Edel-bogs instead.  I want to switch to a Holley or Proform 750 with vacuum secondaries soon.  I'm worried about the more complicated tuning process with those carbs but it can't be any worse than the Edelbog...
C500
Quote from: ws23rt on May 17, 2016, 07:08:32 PM
Heh heh, good point... although food for thought with the EFI, carb it is for now.
Hi Duncan,
Good to see the build coming together  :2thumbs:
My buddy Dennis has almost the exact same build using the HDP 271/CH4B/HP manifolds and I recommended the ProForm 750 street series carb for his combo. The car runs fantastic and even gets 15mpg on the hwy cruising at 60 mph.  :yesnod:
Charger_Dart
If your interested in a Proform 750, I have a nice used 67213 that I was getting ready to list on Ebay but would rather sell it to another member here. PM me if your interested.
Mike
68 Charger R/T & 68 Dart GT Convertible
C500
Quote from: firefighter3931 on May 18, 2016, 07:23:04 AM
Hi Duncan,
Thanks Ron... do you know if your buddy has the vacuum or mechanical secondary?
C500
Quote from: Charger_Dart on May 18, 2016, 12:25:12 PM
Mike
Definitely keen on a Proform, but would like one new outta the box. Yours is a double pumper?
Quote from: C500 on May 18, 2016, 02:03:06 PM
Hi Duncan,
His is the double pumper (mechanical secondary)  :yesnod:
The 67213 PF carb that ChargerDart has for sale is the one I would recommend for yours. It even has an adjustable electric choke  :2thumbs:
C500
Quote from: firefighter3931 on May 18, 2016, 03:14:17 PM
Hi Duncan,
Ron - why would a mechanical be better for mine over a vacuum secondary (67213 is mechanical)?
Quote from: C500 on May 18, 2016, 03:28:05 PM
Hi Duncan,
Throttle response is allways much sharper with a double pumper once they're tuned.  :icon_smile_big:
A 750 cfm DP carb is fine on a 440 with a dual plane intake manifold and it's not too much carb contrary to popular belief  ;)
Yes, the 67213 is a mechanical secondary street series carb  :yesnod:
http://www.summitracing.com/int/parts/pro-67213/overview/
C500
Quote from: firefighter3931 on May 18, 2016, 03:43:25 PM
Hi Duncan,
:cheers: :cheers: :cheers:
XH29N0G
The 67213 is what I would try.  All this talk of fumes with carb somehow brought this to mind https://www.youtube.com/watch?v=bPXVGQnJm0w the line about the smell of napalm in the morning.
Fumes come from the lack of converters, not carbs. Cut the cats off of any modern car and guess what..... it smells like gas..... my 92 5.0, 06 silverado, and 07 charger's exhaust all smell just like the 69.
    Im with ron, mild street 440, 750 double pumper of whichever brand you prefer holley, proform or quickfuel.
flyinlow
I had good results with a Quick Fuel Hot Rod series 780 VS. Screw driver adjustable vacuum secondarys , four corner idle mixture adjust, removable air bleeds, all make for easy tuning.  :Twocents:
Yea ,ok, I did replace it with FiTech FI. I can take the carb with me for road trips as a back up.
myk
I wonder if Ron will ever try EFI...
C500
Quote from: flyinlow on May 18, 2016, 08:11:02 PM
How do you rate the Fitech? -any problems?
flyinlow
Problem ; one big one, got it figured out. http://www.dodgecharger.com/forum/index.php/topic,123886.0.html
I only have about 30 miles on it so far. Starts well and it learns. So far ,so good.
69wannabe
I am a carburetor fan myself but I am an efi fan too!! I had a holley 750 DP on my stock stroke 440 that ran great and if I still had that engine in my charger I would have never made the jump to the fi tech system I don't think. I went from the 440 to a 493 stroker and went up to a holley 850 DP and it ran good but I was never as satisfied with it like I was the 750 I had on the 440. I tried tuning it with bigger jets then bigger pump squirter's and then different pump cams and it still wouldn't rev clean from an idle. Always had a stumble I couldn't completely out of it. On the road it ran pretty good tho. I decided to try the fi tech 600 hp throttle body and the fuel command center and it works pretty good besides a few minor adjustments that could be made to improve the starting part of it but it has no stumbles and has great response and driveability. It starts good but I think it could start a little better but I haven't messed with it lately since it's running great lately. Not hating on carbs and one good thing about the fi tech system is if something fails I can bolt the carb back on it in less than 30 mins and be up and running again if necessary!!
HeavyFuel
All the talk about fuel smell.   :shruggy:
I've got the original Carter installed, and pretty much the only time I smell gas is when the air cleaner is removed and not all the time.
Never a raw gas odor when the car is running.  I can't remember smelling like gas after driving or working on the car.   :shruggy:
66chargertoy
Hi Duncan,
Hi Ron. Just to let you know that my carb is in fact a Proform Race Series 750 vaccum secondary,https://www.proformparts.com/product-exec/product_id/871/nm/PROFORM_reg_RACE_SERIES_CARBURETOR_b_750_CFM_b_VACUUM_SECONDARY/category_id/181 . Great carb, starts up right away with a couple of pumps. Of course, need to feather it for a little while till it warms up. After it's all warmed up, starts up with no problem. I can just reach in and turn the key.
1966 440 Charger
