Which Brake Fluid
Started by blinkey, May 02, 2016, 06:49:25 PM
blinkey
  69 charger with standard brakes whish brake fluid should I be using?  On top of the master cylinder it says  USE SAE 70
BLK 68 R/T
Are you starting fresh with the brakes? If so I would go with DOT 5 fluid, that way it won't dissolve paint if you spill or get a leak. Standard fluid is the DOT 3 which is probably what's in it if you are not starting from scratch.
blinkey
    No, I just bought the car this way and when I looked at the master it said use SAE 70 so I dont know whats in it,,,,whats safe to use
BLK 68 R/T
DOT 3 is what you want to use.
