Oil pressure
Started by rsw0331usmc, April 17, 2016, 12:01:43 PM
rsw0331usmc
I was just out tooling around in my '68. I noticed the oil pressure gauge pegged to the limit. I'm hoping the gauge itself or sending unit is just screwed but I had a scary thought. I was wondering if the cam bearing was spun preventing oil flow. I didn't hear the rockers or lifters raising hell. Any ideas?
birdsandbees
Sender wire is chafed to ground..
1970 'Bird RM23UOA170163
1969 'Bee WM21H9A230241
1964 Dodge 440 62422504487
Sublime/Sixpack
Questions:
-Does the needle peg when you turn the key on (engine not running)?
-With engine running, needle pegged, what does the needle do when you turn the key off? Does it momentarily stay pegged, then notch to the left, then back to the right, then slowly move left to zero?
