Water pump question
Started by Dino, April 13, 2016, 02:31:47 PM
With the water pump removed it's easy to spin it by hand but once installed on the housing I cannot turn it by hand. Is that normal? I know there's a spring on the pump but I don't recall how much pressure there should be on it.
mopar0166
no , you should be able to spin the water pump once installed minus belts
Some water pump housings are incompatible with certain pumps, rotor-to-housing interference. (8-vane pump in a 6-vane housing)
This is the original pump. I removed it last summer.  Dammit I'm supposed to paint the engine this Saturday.    :brickwall:
I'm confused. I just checked again and now it spins. I hear a bit of screeching though as if the vanes are touching the housing but it's not a lot.
cdr
Quote from: Dino on April 13, 2016, 03:17:04 PM
not all gasket brands are the same thickness. also check for rust build up inside the housing.
It may be the gasket yeah, I didn't think of that. There's no rust inside, I cleaned it all up when I took it apart. I do recall one or two vanes having a bit of a shiny tip. I could grind the very tip of the vanes but I don't want to throw the whole thing out of balance either. Maybe I should grind the inside of the housing a bit?   :shruggy:
ws23rt
Try putting four washers of gasket thickness on to see if that is really the issue.
I find it hard to believe the surfaces are warped enough as to cause your question but trying this might put it to rest.
I guess the gasket was too thin. I added another one and that solved it.   :2thumbs:
