How to rebuild PS pump
Started by grdprx, March 22, 2016, 05:26:51 PM
grdprx
How does one rebuild a power steering pump?  I don't see how it comes apart, let alone know how to get the pulley off.  I have a 1968 TRW pump that is leaking at the bottom front edge.  I also had the internals shift on me when I took the bracket off, the back bolt hole doesn't line up.  I've come to realize these old pumps are hard to come by now...
BLK 68 R/T
The pulley takes a special tool to remove it, it is a press fit pulley. The pump just has a large o-ring that seals it to the reservoir. I'm not too familiar with TRW pumps but on the saginaw pumps once you remove the mounting brackets the studs that they mount to unscrew and that is what holds the pump to the housing. I would think that TRW would be similar?
grdprx
Check that action out!  Thanks man!  Is a little play on the shaft normal?
crj1968
Yes the shaft play is normal.
I just replaced my federal pump and old and new both had the shaft play I think it is to absorb misalignment a bit.
I used a puller from harbor freight worked great.
