starter
Started by Sgtmajor, March 20, 2016, 03:21:53 PM
Sgtmajor
How do you change the starter on a 1974 dodge charger 400 2 barrel carb
disconnect battery, jack up car, place jack stands under car, remove the 2 battery & solenoid wires to starter, remove the 2 bolts or nuts that hold starter to bellhousing......reverse procedure to install
a service manual will have this info in it
Sgtmajor
Sorry let me rephrase that how do I get to the top bolt on the starter. It seems no direct way to that bolt without removing other parts.
A 5/8" socket on a long extension is the easiest way to get the top bolt; it's a little off of a direct shot but the socket will fit the bolt well enough to loosen it or if you're patient enough, a starter wrench.
birdsandbees
A "wobble" extension at that!  :yesnod:
1970 'Bird RM23UOA170163
1969 'Bee WM21H9A230241
1964 Dodge 440 62422504487
A box wrench fits mine without any problem, no need to remove other parts
myk
Quote from: John_Kunkel on March 20, 2016, 04:44:10 PM
I have never seen that before.   Thanks for sharing....
VegasCharger
Quote from: birdsandbees on March 20, 2016, 04:47:55 PM
Yep, long extension with wobble drive. And with wobble drive, preferably used a 6 point socket.
Mopar Nut
Quote from: VegasCharger on March 21, 2016, 04:52:36 PM
x3
