Fuel Lines
Started by slumbers, March 15, 2016, 03:10:07 PM
slumbers
Hi Gentlemen .
I have 2 fuel lines from my Fuel tank on my 68 Charger R/T to the engine . One is 3/8" and the other 5/16"  . I assume the the larger is the Fuel Feed line to the
pump  and the other a return ?
Where would the return connect to at the engine compartment ?
I will be fitting a Holley 750 carburettor does that have a provision for this or am I missing something ?
Thanks Dave
BLK 68 R/T
The smaller line connects to a fuel vapor separator which mounts just above the fuel pump on the 440/Hemi cars as they are the only ones that received it.
http://www.bing.com/images/search?q=440+mopar+fuel+vapor+separator&id=C0271A819D6812BFD7D0ED212B81618D2CF7657D&FORM=IQFRBA
Check your gas tanks fuel pickup/gauge sending unit. (By the axle.) Be certain that both connecting hoses are in good condition and the ground strap is still there.  :2thumbs:
303 Mopar
If you are not doing a concurs resto, a cheaper and easier option is to get a dual line fuel filter.
slumbers
Thanks for the info !
Will be replacing all the hoses as they are perished , I hav'nt seen a Ground Strap ?
Is this to earth the pipework to the tank ?
A steel strap with clips on each end, goes from fuel line to sender's fuel nipple. (Passed the rubber hose.)
slumbers
Thanks for all the info I found some pictures of the Earth strap on Google . I will probably go down the duel filter route  ;)
Tally Ho from the UK !!   :cheers:
