Driveshaft length
Started by slumbers, February 03, 2016, 03:25:57 PM
slumbers
Greetings from the UK  ;)
My 1968 Dodge Charger 440 R/T arrived from your Beautiful country minus it's Driveshaft !
What kind of length driveshaft should be fitted , I have a 440/ 727 Torqueflite Auto and 8 3/4 Differential.
If I cant obtain a complete one how long is the Yoke at the Front ?
The drive out of the diff is approx 3" where the U/J fits and the U/J mounts would be around 1 1/16"
Slumbers
Shaft length is 52.07" between u-joint cup centers
Diameter is 3"
U-joint is 7290
Part number is 2852162
Length of yoke is not included in propeller shaft length
slumbers
slumbers
I just measured the yoke that is still on the diff and that measures 3.75 " across . Most  of the driveshafts I have seen secondhand have 3" diameter with 3 or 3.5" yokes , am I going to find it hard to find something to fit ? Summit racing
Have a driveshaft p/n M7290U will this fit ? :shruggy:
That driveshaft is perfect for you if you have somebody to shorten the tube to the correct length and weld the yoke.
slumbers
Getting it shortened is not a problem . Thank you John for your advice  Brgds Dave 🙂👍
