u c a bushings
Started by Lennard, December 29, 2015, 01:59:44 PM
Lennard
For a power cruiser, which would be smarter to use...polyurethane upper control arm bushings or the Moog offset rubber bushings?
HPP
Offset. These old cars need as much positive caster as you can dial in to them. The caster will create more noticeable results than the urethane.
Lennard
Okay,  thanks for your advice.  Offset bushings it is. :2thumbs:
mopar4don
Quote from: Lennard on December 29, 2015, 01:59:44 PM
Quote from: HPP on December 29, 2015, 02:24:25 PM
How do you adjust the Moog offset rubber bushings?
I am looking to replace all the bushings in my 69 Charger and am looking for advise.
Whats wrong with stock style bushings?
polywideblock
  and 71 GA4  383 magnum  SE
six-tee-nine
The idea behind these it to swing the balljoint in the uca's backwards, towards the firewall so to speak.
This to increase positive caster as said above.
positive caster has a large influence on bump steer and straight out stability of the vehicle.
HPP
Nothing is wrong with the stock bushings, but one of the big shortcoming in the classic mopar design is the lack of adjustability the upper arms have. The offset bushings gain a couple of degrees of additional adjustment without having to pay big bucks for new control arms and retaining a stock look.
Additional positive caster create improved high speed stability, creates additional steering effort to offset some of the mopar over-assist, improves return to center characteristics when exiting turns, and increases dynamic camber gain under compression to better keep the tire upright against the road surface. All positives in my book.
mopar4don
So if I were to install these offset bushings, who adjusts them?
Me, or the guy at the alignment shop?
Kern Dog
The bushings are not adjustable. The gains they allow are due to how they are installed.
