Will they fit
Started by holanae, October 11, 2015, 06:19:26 PM
holanae
Local guy has a set of wheels with the correct bolt pattern. 18 x 8 with 4 in bs, 20 x 10 with 4.5 bs.  Will they fit or is the back spacing on the rears not enough.  Running stock suspension.  Will probably put a 295 on the rear.
1974dodgecharger
that's gangsta stuff don't do that...
holanae
I read your comments in the sticky on the main page about wheel, but couldn't find where you posted your offset/backspacing numbers.  I'm assuming you went with a 5 or 5.5 bs on the rear. Just curious to how close the tire will be to the outer fender with a 4.5 bs.
1974dodgecharger
4.75 up front and 5.5 in the rear....zero offset of course.  18s and 20s
Kern Dog
LESS backspacing puts the wheel rim inboard more, closer to the leaf springs and wheel tubs in the rear. The numbers you list might be okay. My 18x18s in the rear have 4 3/4" BS but I also have a 66-67 B body housing, it is about 5/8" narrower than my stock 68-70 housing. 1970 Charger.
