Cooling cliche
Started by myk, September 28, 2015, 03:07:12 PM
myk
So how does the old saying go?  If you're overheating at speed, it's a coolant flow problem, but if you're overheating at idle it's an airflow problem?  Did I get that right?
Charger's been running hotter lately, like 230* in traffic hotter, and I thought it was because of my new initial timing number of 24*.  I dialed it back to 18* initial and it helped, but it's just taking longer to get to 230*.  At speed the car can maintain 180* on the hottest days.  I've searched and studied as much as I could about an airflow problem and since I have a fan shroud I figured my fan clutch, which has been on the car for the 20 years that I've owned it, can be the only other problem.  I've also learned that there is no reliable way to test a fan clutch, and the FSM even states to just "replace it with a known good unit."  I bought the Hayden 2765 that everyone's talked about and mounted it today.  I have to say I don't like the bolts riding on the outside of the mounting flange but it seems tight enough.  Man, those bolts were tricky and thank God for small hands.  I should've listened to A383Wing about the studs and nuts but I'm the type to try and ice skate uphill.  Questions:
*How is it that all of the "correct" clutches bury themselves into the radiator by being too long?  I am running a stock spec sized 26" radiator, but I can see that many others on here have had the same problem.
*I want to verify the proper "behaviors" of a thermostatic clutch fan so I'll know what to look for when testing this thing.  So, the fan is supposed to be "freewheeling" until the engine 'temps make the clutch lock up?  And then disengage when it is appropriate to do so?  Is the fan supposed to turn at all when the engine is cold?  Because with my old fan clutch the fan always turned no matter the 'temps.
*Is there anything else that could be causing the low speed over-heating?  Again it's my understanding that low speed overheating is an airflow problem, but someone please correct me if I'm wrong.
Additionally, I have a new aluminum radiator and a Milidon high-flow water pump and t-stat ready to go in.  I hope that cooling will be one less thing to think about after all is said and done.  Thanks for any input...
cdr
cdr
hot running in traffic is normally an air flow problem, not always, but is the most common problem.
myk
Thanks 'CD.  Hopefully this new clutch will solve the problem, although now I think the fan sits too far back from the shroud.  Guess the new, fat aluminum 'rad will help out in that department...
The distance from the rad makes no difference as long as the fan is within the shroud
Simple check for airflow is a peice of cardboard in front of the rad. The fan should be able to hold it against the rad at idle.
Is your current rad a 2 row or 3 row? My mild 383 would get up to 200 on summer days in traffic with a 2 row. Swapped to a stock 3 row and it will idle all day at 180
myk
Current 'rad is a 2 row parts store piece.  Like the clutch, the 'rad came with the car many moons ago...
Nothing wrong with a parts store radiator. I would venture to say you need more capacity for your given airflow. If you already have the aluminum one on hand, put it in. Night and day difference.
Had my temps go up about 30 degrees a while back, and it would do it real quick as well.  Turned out to be a tiny leak on the bottom hose at the waterpump.  Tightened the clamp and temps went back down to normal.  Might want to check the system for any leaks, no matter how small.
And proper level. Add an overflow bottle if you havnt already, and keep the radiator full. If you only have the drain hose on and run the rad a few inches down, it will run hotter.
1974dodgecharger
had a 2 row 22inch rad with no shroud and I was good in AZ got up to 210 in very hot days sitting there and driving on highway 190 also.
check the fan if you can turn it by hand pretty easy the clutch is shot and if it has resistance then your good that's how I was told to test it.  Also you can sit there wihle you turn the car on and let it reach up to your clutches temp, 'kick' and feel the fan move more air.
I switched to electric myk and to be honest I like it better than mechanical......just me.
justcruisin
The 2765 hayden is a medium duty clutch, not ideal, especially with high pitched fans. The only reason to use it is if you have a clearance issue. The HD version has more surface area for drive but it does put the clutch a further 5/8" closer to the radiator. Depending on the amount of cooling you need the 2765 may work for you. A spacing ring can be fabbed up to help with the bolt circle.
myk
Quote from: Dino on September 28, 2015, 08:23:22 PM
Yeah about that.  I went outside a few days ago and there was a small puddle of coolant under the motor.  I didn't find any loose hoses so I figured my 12 year old Eddy pump had finally bitten the bullet.  The coolant recovery bottle was properly hooked up and not leaking either.
As for the jaguar clutch, I didn't want to run it either but...like I said earlier all of the "correct" clutches bury themselves into my radiator.
I dreamed of having an electric fan and water pump set up but honestly, I just don't trust electronic accessories enough to run them in the Charger.  I'm still recovering from the electric fuel pump nonsense and I need this car to be daily driver reliable.  Thanks for all of the feedback guys.  I'm going to run the car for the last big cruise of the year this week and hope the clutch is the issue after all...
1974dodgecharger
I don't like electric water pumps either im kinda scared  :icon_smile_big: electric fans on the other hand I trust...... :2thumbs:
bill440rt
The tiny 2-row radiator is definitely a culprit. As mentioned put that aluminum rad in there & watch your temps decrease.  :yesnod:
A few words about fan clutches. Tony's Parts has been reproducing the correct BB fan clutch for non-A/C cars for quite a while now. This has the shorter shaft, & is a correct repro. Scroll down about 1/4 page:
http://www.tonysparts.com/newproductsB.htm
Cars with the heavy duty cooling package (typically those with A/C), used a fan clutch with the spring on the front. Part# is 2658456. They are really hard to find too, hence the use of the Hayden clutch. I don't trust the smaller hub face on the Hayden, either.
A correct "parts store" replacement clutch was the Eaton FC-28, which is exactly like the "456" clutch. Both of these have the correct shorter shaft to place the fan correctly in the shroud. Not as hard to find, they do turn up time to time on eBay and such.
Mopar's clutch in their viscous fan package is similar, with a slightly longer shaft. This could be tricky on cars with a thicker radiator. It fits on my '68 with a 3-row. It is close (maybe 1/2" away or so?), but it does fit. I've since located a FC-28, which I'll be swapping in soon.
HPP
The cliche is generally correct. Its not 100%, but in general, yes.
I haven't had any issues with interference, but then again I mostly deal with small blocks, so a big block may present different issues.
When you say a clutch fan "freewheels" I'd say it depends on how and what you mean by freewheel and the type of clutch. If you can spin it easily by hand and watch it go round and round with one spin, then your clutch is shot. You can turn them by hand, but you should be able to feel resistance and it should not spin freely at all. The best thermostatic clutch fans will engage/disengage not just with air flow but also air temp. There should be some resistance felt when the engine is off. They should briefly engage at start up until the fluid is warmed and displaced, and then they should disengage and engage with a specific temp range. Now, when they disengage, it does not mean they stop spinning altogether. What happens is they will turn 50% of engine speed, but will still turn. They just are slipping. Once the temp reaches its threshold limit, then it locks up and move at engine speed. When you shut down the warm engine, it will be easier to turn by hand because of the displaced fluid and warm temps.
If you have a shroud, you want the fan half in and half out if at all possible.
One thing many people overlook is pulley ratios. If you have mixed and matched and altered pulleys or installed overdrive pulleys, you have changed the ratio and opened up the potential for overheating. If you overheating is suddenly occurring, then it likely isn't  this, but I mention it for others following the thread.
myk
Bill thanks for the link to Tony's parts but, oi vey; that's a lot of scratch for a clutch.
I think I now understand about the fans and how they should be spinning.  Over the years I've never noticed the fan increasing in speed or slowing down.  Maybe my clutch has been defective all of this time?  Someone suggested that I mark one of the blades and time it with a timing light.
You're right about the pulleys though; this was originally an AC car but I ripped it out and recall changing something; I don't recall what exactly but a pulley or two did change, for sure.  I'm going to test the car with just the clutch changed.  When the car heats up I'll try to see any leaks that I don't see now...
A veteran mechanic friend of mine proved to me that the clutch fan can affect temps at road speed...depends on the car.
HPP
The Tony's clutch is for die hard, gotta be original and have the right stampings crowd. There are less expensive ways to get the same thing.
Its hard to see the change in spinning on the fan, but if you have a quiet exhaust, you certainly can hear it. It will almost sound like an electric fan turning on as it locks up. if you clutch is locked up and spinning full on all the time, I'd think you wouldn't have overheating problems. Now if it was running 50% of capacity, and is further slipping and loosing efficiency, then you might notice the temp climbing more.
Similar thing with pulleys. If your ratio was outta of whack way back when you changed them, you would have noticed then. It wouldn't be creeping up now.
myk
Quote from: John_Kunkel on September 29, 2015, 02:52:59 PM
I think I can see that....sort of.
Quote from: HPP on September 29, 2015, 02:58:26 PM
Maybe before the headers I could've heard the fan but not now.  Actually, even before the headers I don't ever remember hearing the fan lock up as you describe but the car has always been loud to me anyway.
In any case, after making sure the Hayden clutch was on securely I drove the car out for a bit and just parked and left it running for about a half hour.  Temps slowly creeped up and topped off at 220*, which isn't where I want it but at least it isn't 230+ any more.  I did not run the pusher fan up front to help the clutch fan.  No leaks were spotted during the cool down period afterward, which still leaves me wondering about the puddle of coolant I found underneath the car a few days ago.
Just how does the water pump weep hole behave when it's starting to go, anyway?  On my '99 Bird I lost the water pump just minutes after the weep hole started to leak...
68CoronetRT
I just went down this road and here's what I came up with.
3 row aluminum Champion radiator, custom build shroud and Hayden Jag clutch keeps the engine at 180 while in the garage, when it was 95 degrees here last week with like 90% humidity(This is SD.... WTF is up with this weather?). The shroud IMO is key.
myk
Yeah I got all that.  We'll see what happens when the Milidon water pump and aluminum radiator with 1" tubes x 2 goes in...
68CoronetRT
Yea, I'm running the Milodan WP and T stat as well.
bill440rt
From what I understand yeah Tony's clutch is dead-on visually, but still has no numbers or stampings. So from a fitment standpoint of short shaft clutches yeah it's the most correct and no worries from the smaller mount hub.
If you're looking for sticker shock go price an original.  :faint:
Myk, if the Hayden clutch does not work for you check the measurement from the water pump hub face to the radiator. If you have enough clearance then the MP 4095704 clutch may be your ticket. It has a slightly longer stem, but it works very well.
You'll still notice a big difference with the aluminum radiator. My '69 with the aluminum Griffin and electric fan setup runs very cool. Hottest it ever got was 190* with the A/C on, this was on a very hot summer day around 105*.  :cheers:
Quote from: myk on September 29, 2015, 07:21:25 PM
there was an extensive test done on water pumps here, and the Milidon from what I remember didn't cut it...stick with a stock pump, but you don't listen to me anyway   :D
Quote from: A383Wing on September 29, 2015, 08:24:23 PM
That hasn't been my experience. Over the years I've used a half dozen of those pumps in various builds and never had an issue. The Milidon HV pump works like a champ and takes a beating....some have seen 7000rpm at the strip and didn't blink. The anti cavitation plate is a huge bonus....nice improvement vs a stock pump.
myk
Now wait a minute I listen to you just fine lol.  Seriously, doesn't the Godfather Ron run the Milidon and endorse it fully?
Kern Dog
Quote from: c00nhunterjoe on September 28, 2015, 06:45:09 PM
Nothing wrong? Have you inspected the size of the cooling tubes? Many are woefully small and flow barely half of a stock OEM radiator. I have found that the 26" radiators from the 1985-89 Diplomat cop cars have more than adequate flow. You have to be careful though about the generic replacements for those applications. They may look similar and fit the same, but look below the cap and sometimes you'll see that the "core" is fitted with smaller, more restrictive tubes.
I run a Griffin 2 core, but the tubes are almost 1 1/2 times the size of the stock ones my original 26" 318 with A/C unit had. I have run with and without a shroud, but I do have a 7 blade stock fan and a thermo-style fan clutch. Another thing some forget is the rubber seals that are on the underside of the hood and the back side of the 1970 front bumper. ZERO overheating issues. I've had the car on the road since 2002 with this radiator. Temperatures from 40 degrees to 105 and it has never boiled over once. Maybe I've had a run of good luck, maybe I just got it right on accident....
Quote from: myk on September 29, 2015, 09:13:36 PM
I can't find the cooling thread that had maybe 4+ water pumps tested against each other...you might want to find it and read up....
cdr
Quote from: cdr on September 29, 2015, 10:38:08 PM
the milidon pump is the good one.
http://www.dodgecharger.com/forum/index.php/topic,60599.msg675761.html#msg675761
yea, my bad....I could not remember which of the high priced pumps were not all that good...that thread needs to be made a sticky, seems many here have cooling issues related to mis-matched pulleys and bad design pumps
I  told him to use studs  and nuts on the fan clutch, like he said, he doesn't listen to me
myk
Quote from: A383Wing on September 29, 2015, 11:37:48 PM
Yeah I'm never gonna hear the end of that.   :smilielol:
Well I might install everything else tomorrow.  I'll let you guys know if the car melts into molten steel afterwards...
fy469rtse
You had better get this right Myk, otherwise you won't hear the end of it
I have run quite a few different pumps over the years,
Hemi pump stock, 7 blade I think from memory, towing package with the anti cavitation plate, rebuild able too,
Champion 26" large open three core, almost the width of a 4, good price radiators too
I use a high speed rated stainless blade flex fan 7 blade,
The idea of these is they work better at idle and at high rpm the fan blades flatten out when air flow good coming through car , similar to clutch fan, although you must buy a good one ,
The water pump thread is stickied , have a good read
Mine runs 180 all day everyday.
512 victor headed stroker 11.75 /1 comp
With the overflow bottle , make sure you get a modern radiator cap that seals to neck and top of neck, like a modern cars overflow, when hot cap will open and push excess to overflow bottle, and retrieve it when needed,
Does that make sense
Quote from: Kern Dog on September 29, 2015, 09:45:46 PM
I had a "parts store" 26" 3 row in my belevedere for years. The 440 in it was far from mild and i had no issues cooling it.
myk
Quote from: fy469rtse on September 30, 2015, 06:28:42 AM
I'll look into that cap, that's a good idea.  Question: how long do I have to let the gasket and sealant on the pump and the t-stat set before I refill the system with coolant?  I know on some cars like my 90's vehicles there's no waiting time or even sealant required...
cdr
it is a sticky, 4th one down in the engines & transmissions section
myk
Allllllrighty then.  After removing and replacing the water pump, radiator and fan clutch, and filling the radiator TWICE because I left the petcock turned the wrong way and pissed my first batch of coolant all over the driveway, I got the car to idle for 40 minutes and hold 190*.  Granted, it was only 80* outside today but running the car in similar conditions two days ago got me 210-220* after 30 minutes.  And this is WITHOUT even bothering to reinstall the electric fan.  Before, I could hold the car at 200-210* but that was with the help of the pusher fan.  After removing the Edelbrock Victor pump I noticed a streak of residue out of the weep hole-looks like it's been doing this for some time but gradually, since I never noticed any major leaks or spills.
Now, I'm starting to hear things about special pitfalls regarding aluminum radiators.  Something about needing a ground strap for the radiator, the quality or type of the water, etc, etc?  Last thing I want to do is trash my new 'rad and revitalized cooling system.  Also, I can't remember the last time I had to refill the 727 with fluid; what do these things take these days?  I lost a noticeable amount of ATF during the swap.  I'll test the car tonight and tomorrow and hopefully I'll be good to go for the last Cruisin' Grand on Friday.  In any case, thanks to everyone for helping out, except for Bryan because I don't listen to what he says anyway.  Lol, just kidding, he's the one who pointed me to that great radiator deal from Engineered Cooling Products.  It really works!   :cheers:
At least you know its thoroughly flushed... lol. Glad to hear its cooling. The grou d strap has been argued for years. I personally have never had an issue without them. The theory on the water is if you use tap or well water, it has minerals in it that can speed up corrosion. Distilled water is an option. Fwiw, i run tap water 50/50 and a bottle of water wetter. 16 years on this engine with no problems. The race car has been together 15 years running ALL aluminum components with no issues either on 100% well water/ 1 bottle water wetter.
As for the trans- if its red, you can pretty much use it to top it off. Atf 3,atf4, dexron, mercon, whatever. I wouldnt run the specialty stuff for cvt trans or weird stuff like that.... although i did run turbine oil in one of mine for a while as an experiment....lol
if you mounted the aluminum radiator to the core support with screws or nuts & bolts, it's already grounded to the body. Some say use a zinc anode, but I have never seen an issue using aluminum rads in cars over the years, even the new cars use them without any change in coolant or zinc anode.
Curious, what fan clutch did you finally end up using?
myk
Quote from: A383Wing on September 30, 2015, 09:26:45 PM
I bought the Hayden 2765.  Please don't yell at me haha.
So on a 40 mile one way cruise this thing held 160.  Is there such a thing as too cold?
I would have put a 180* stat in, but that's just my opinion
myk
Quote from: A383Wing on September 30, 2015, 11:40:33 PM
I am putting a 180* t stat in tomorrow; it came late and I didn't want to wait tonight so I just buttoned everything up...
