Body bolts and cips
Started by Dino, September 17, 2015, 11:43:10 PM
Does anyone know if the body bolts and clips are commonly found in hardware stores or auto parts stores?  I lost one of the radiator bolts with the big washer and a few of the battery tray bolts are not original.  One of the clips is also beyond saving as it was welded to the inner fender...don't ask.
Mopar Nut
Alaskan_TA
R/T Specialties has the radiator bolts to the body & the u-clips & small bolts for the shrouds as well.
Moparparts
I have the original radiator bolts & clips PM or E-Mail me
ODZKing
I've had good luck at Lowes finding orig style body bolts.  The Lowes here has a set of drawers in the nut/bolt section called automotive. Very helpful.
:iagree: I've been surprised at some of the stuff I find in the Lowe's nut/bolt/hardware section. Disappointed at other times though. My local Sears Hardware also has some cool stuff - although I usually get "specialty" hardware there (stainless, oddball heads, etc.) instead of original equipment type of fasteners.
bill440rt
They will be similar and do the job but will not be "OE-correct" with the right head markings, etc. Clips may have a different shape as well.
I've used them in a pinch, nothing wrong with it if you're not building an "OE" car.
