69 charger rims
Started by tiki, September 02, 2015, 09:36:06 AM
stripedelete
1. magnums
2. cragers
3. road wheels.  (not repop'ed in 15 or not well anyway)
I've got magnums 15x8 rear, 15x6 front -  off the  shelf
The 15x6 gives it a great "period look".  They ride and drive great, but then again, I don't own any driving gloves.
triple_green
Here's what everyone has that wants no problems at stock ride height:
Front- magnum (or ?) 500 15x7 4" BS
235x60x15 tires
Rear-Magnum 500 15x8 4.25" BS
275X60X15 tires
Looks 60s but wide and agressive. Only issue is the 275 60 is 28" tall not 26" like original tire. So  you loose a little "grunt" on the low end.
I have had this combo for 15 years.
68 Charger 383 HP grandma car (the orignal 3X)
Stegs
Quote from: triple_green on September 02, 2015, 09:37:42 PM
235x60x15 tires
275X60X15 tires
bingo, thats what i needed to know
any issues with clearance? going to save this post so when i order rims and tires i know what to get!
E86/A47
I like the magnums and cragers, my car came with American racing wheels that resemble cragers.
tiki
Thanks triple green do you think 235/70/15 will rub on the front,just a little more sidewall?I have them brand new as a left over project that i changed my mind, could save me a few bucks... :cheers:
6pkrtse
CRAGARS for me.
1963 Belvedere 413 Max Wedge
1970 Charger R/T S.E. 440 sixpack.
1970 Challenger R/T Drag Radial 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Road Runner 383 4 BBL
1974 Chrysler New Yorker 440 4 BBL
1996 Dodge Ram 2500 V-10 488 cu in.
2004 Dodge Ram 3500 CTD Dually 6x6
2012 Challenger R/T Classic
charge69
My Cragars are the same size as Triple_Green uses on his Magnums. I, also, use a 275X60X15 on the rear but use a B.F. Goodrich Radial T/A on the front that is 225x70x15 to get the same approx. height (27.79") for both front and rear.
The rear tires certainly are not the widest you can mount but these sizes are pain-free with no clearance issues.
tiki
Thanks for the response your ride is beautiful,Im going w/275/60/15 rear and 235/70/15 in the front because i had 2 front tires (brand new)left over from another project that i changed my mind...If I have clearance problems the 2 front tires will go back on the future pile lol :cheers:
tiki
charge69 do you have 7 inch wide on the back and 6 inch wide on the front?
triple_green
the 235 70 15 is almost 2" taller than the 235 60 15. I would have to measure.
Also 0.6" narrower tread width.
My guess is that it would be ok.
tiki
triple green post me a snap shot of your ride... :cheers:
charge69
Yep,  my rims are 7" on the front and 8" on the rear.  Standard back spacing (somewhere around 4"). No problems at all with the rims or tires clearing the suspension.  You should have no problems either with your choice.
tiki
I cant wait Friday delivery of rims (Magnum 500) Tuesday  275/60/15 Goodrich t/a tires - I just cleaned the raised white letter tires on the other 2.Tomorrow I get the front windshield clips,install them and get the glass guy to install the glass,got the gasket for the windshield today,almost ready to hear the engine through the exhaust for the first time,oh yea put the doors on that would help... :drool5:
tiki
triple_green
I just measured on my own car. The extra 2" of height should be fine. There is lots of room inside the upper fender well. If your ride height is the same as mine, the tire will come close to the bottom of the wheel opening visually.
That black car you posted the picture of may be the best looking second gen I've ever seen!
3X
303 Mopar
I have 235/70/15's front and 275/60/15's rear. Measuring from lowest point on rim to top of wheel well 21" front and 21.5" rear.  No clearance issues.
charge69
303 Mopar:   Beautiful Charger and nice choice of rims!  :icon_smile_big:
303 Mopar
Quote from: charge69 on September 04, 2015, 04:24:45 PM
Thanks!  I need to switch out the tires, but other priorities like suspension and brakes come first.
triple_green
Here's an old pic from the front
charge69
triple_green:  Another beautiful Charger!
tiki
rims go on the front today i will take some pics later :drool5:
Mopar Nut
Quote from: tiki on September 05, 2015, 06:16:07 AM
Looking forward to seeing them!
69wannabe
I'm running the chrome magnum's on my car. Got 15 x 8's all the way around with BFG 275 60 15's on the rear and 225 70 15's on the front. I started out with 245 60 15's on the front but it seemed like the car wanted to follow every other groove in the road!! I don't really know why but it didn't drive good at all. I had 225 70 15's on it all the way around when I had it dressed up in the general uniform with the vector's on it and it drove fine that way too so after the 245 60's wanted to wander I just went back to the 225 70's. I did like the look of the 245's on the front but look's ain't everything when it doesn't drive good!!!
tiki
I got the front done...
BrianShaughnessy
Just took the 15's off Black Betty and put on the 17/18 combo.
