neutral safty switch
Started by GN, July 24, 2015, 07:25:59 PM
GN
Is their away to test the nss out of the transmission? And how can I tell if it is bad in the car? I turn the key and nothing happens.  New battery installed.  Ignition switch?
nascarxx29
 Will car start with switch byassed.inside trans theres parts that touches switch think its plastic
,switch can be bad and linkage adjustment or lever in trans.  with switch in trans and a ohmeter moving gearshift see a reading on the pins
1969 R4 Daytona XX29L9B410772
1970 Coronet RT WS23UOA224126
nascarxx29
GN
It will try and start with a screwdriver touching the starter relay terminals.
nascarxx29
Switch has 3 prongs neutral switch and reverse light des your reverse lights work also wiggling shifter can get it going maybe check  linkage
nascarxx29
GN
It was the nss. Thanks for the help.
