400 engine squealing
Started by jhoop, July 12, 2015, 04:50:01 PM
jhoop
I have a 73 400 magnum in my charger that has sat a lot more then it has ran the last 5 years.  I have a loud high pitch squeal that gets louder as the engine warms up.  I have removed all the belts and the squeal is still there so I know it's not one of the accessories or the water pump.  I pulled the distributor and it spins smoothly.  What else am I missing?  Is there something internal to the engine that could cause a squeal like this?
Dodgecharger74
Had a main bearing squeal until it locked up.  Time for a rebuild
74 charger se
82 dodge PU fleetside short box 440
05 magnum 5.7 Hemi
04 rumble bee hemi
71_Charger_R/T
I agree,  I had the same type of thing........ pulled all the belt driven accessories out of the mix....still there.  Tore down the motor and found scored rod and main bearings as well as a stretched #6 connecting rod.  I'd get it before it gets you!
