back up lights always on!
Started by tiki, June 20, 2015, 10:52:12 AM
tiki
Reverse switch out of adjustment?
tiki
Baldwinvette77
I had this happen on my cutlass, i thought it was the switch, so i disconnected it from the shifter, and they still stayed on so it must have been a short.... i never fixed it, i just disconnected them  :lol:
PlainfieldCharger
Quote from: Ghoste on June 20, 2015, 11:03:42 AM
remove the neg battery terminal, take the connector off the reverse switch and with the car not in reverse, put a continuity tester across the terminals. They should be open. If not, shorted switch or wrong one. If it is open like it should be it is being powered incorrectly.  :Twocents:
Always on? Even with the ignition switch off? What year?
If the BU lights shut off with the ignition and if it's a '69 or later, the problem is probably a broken plastic shoe on the rooster comb.
