spare wheel ! Help !
Started by Type14, May 29, 2015, 01:07:29 PM
Type14
Hello everybody,
well, I'm looking for a spare wheel for my 68 charger..... But here in France it's very difficult to find !
Do you know if it's the same rim from challenger, or another brand like Plymouth, ford, volvo........ ?
Type14 from Strasbourg FRANCE
Baldwinvette77
its uses a 4.5x5 bolt pattern, fords share that  :shruggy:
JR
Any 7-8 inch wheel with a 5x4.5 bolt pattern should fit if the center bore hole is large enough.
Do you have any domestic vans or trucks over there that used 5x4.5 bolt pattern?
Baldwinvette77
or any "american imports" ? :lol:
myk
Don't forget the backspacing/offset measurement also...
Type14
Thanks a lot.....
I juste found this in a french site, please have a look and tel me if it's good for my 68.....
http://www.leboncoin.fr/equipement_auto/665351605.htm?ca=1_s
myk
Be sure to check the backspacing/offset.  You want a 4.5 to 5 inch backspacing/zero offset, or the wheel could either be too close to the frame or too far out in the wheel well.  Someone correct me if I'm wrong...
