Organosol effect
Started by bobfist, May 17, 2015, 02:32:13 PM
bobfist
Hi!
Since i cant get any organosol for my tail light panel for my charger 69 i wonder if that paint has structure in it?
Im thinking of painting it with sem structure paint and then dust satin black over, not correct but would it be in the right direction?
www.bobfist.com
Muscle Car Restorations & Reproduction
Sweden
Short answer: yes.
I no longer have the original organisol on my car, if I did I'd run out to study it.  As with any paint that has some grain to it, which I believe it does here as well, you can use another high solid paint and mimick the texture by changing out the spray gun needle and knowing how to use air pressure.  I've seen your work, you know what you're doing so I won't go into detail.
As long as you don't use different paint systems you can certainly top off the work with satin.  They gives you some leeway in case you get some debris in the textured paint.  You'll be able to fix it and finish with a few coats of satin side to side.
I think the original paint can still be bought here, but shipping may not bee easy or even possible.
Charger-Bodie
I used to like to use black epoxy primer sealer,as a sealer. Spray it very dry to get the suede effect,then use a trim black paint over that and your all good. Another option i have been doing the last few is this....if you have access to it its rust oleum textured paint in a spray can . I use that on dashes and steering columns and it works great on tail panels too.
cdr
hey Brian I think this is the paint #   #7220 Textured Black. Rustoleum, it is what i use on my dash & stg column .
The organisol paint I've bought in spray cans was a PITA to use.  I think it's just the nature of the paint, being so textured & heavy.
The factory seemed to be going for the flattest look they could get in a practical way.  From what I recall it was not a totally flat paint but more of a low-gloss paint with heavy texturing.  A truly flat paint layer would be harder to keep clean.
With spray cans, you might try spraying a stone-textured layer first and then using a satin black layer on top to "seal it up" a bit.  I haven't tried this but it's an idea.
bobfist
Thanks everyone i will try this
Here is my car painted and waiting for the boar green vinyl top
www.bobfist.com
Sweden
Charger-Bodie
The rust oleum stuff works great as long as you clean the tip after use by spraying the can upside down, and shake the can between coats.
bobfist
do you think sems structure paint would be as good as rust oleum?
www.bobfist.com
Sweden
Charger-Bodie
I have zero experience with that product.
six-tee-nine
What about regular black paint?
Shoot 2 normal coats, let them flash and put a third misty layer with more air pressure from a little more distance, so it becomes rougher.... could that pass?
Quote from: six-tee-nine on May 18, 2015, 12:32:20 PM
It does work, but I would do that the other way round.  Lay down one dust coat followed directly by a rough coat.  Then apply a wet coat and see if you have to go back to step 2 to add more texture.
I'd go the Rustolrum route though if it's really that close.  Why make it harder than it needs to be right?  I have used Sem products but not that one.  I'd risk it though, it's a good brand.
bobfist
ok ill try sem, its for bumpers and stuff so i guess it will hold up for outside use
www.bobfist.com
Sweden
Quote from: bobfist on May 18, 2015, 01:30:46 PM
It should, but you can always contact Sem and ask if there is a good matte or satin clear coat that can seal their paint.
six-tee-nine
Well, its for the tail so you dont catch bugs there so the paint will be a less attacked then in the front...
maxwellwedge
Original Organosol had an ingredient call suede in it. The original stuff also has a hint of metallic in it as well. Depending on how the line worker applied it, it could be fairly textured or fairly smooth. Frank Badalson has it for sale.....for how much longer - who knows. I believe one of the Charger plants (I think St. Louis) didn't use it because of a state law......they used a flattened standard black instead. This is even shown in the engineering drawings.
Charger-Bodie
Quote from: maxwellwedge on May 19, 2015, 11:48:03 AM
I agree. Back when I was a kid in my dads body shop he had lacquer paint on a mixing bank system. Dmd364 was the number for suede flattener. The money they get for the watered down lacquer now a days is rediculous .
AKcharger
I've had good luck with rustolum® semi-gloss black  :yesnod:
Brock Lee
Proper Organosol is still available at http://autocolorlibrary.com/
The suede additive is not a reducer or flattening agent, it actually changes the consistency of the paint. You will find strange spider web looking formations develop in screw holes and in corners if you are not careful. You really have to dial the gun in just right or it will look like thin silly string coming out of the gun.
hemi-hampton
DDL #9355 is the factory paint code for the Organosol textured black. Some paints stores still sell it but getting very exspensive nowadays. LEON.
Charger-Bodie
Quote from: Brock Lee on May 21, 2015, 05:41:39 PM
The suede additive is a flattener. If you are spraying lacquer paint and it spraying like cobwebs you have it too thick and need to add some thinner.
bill440rt
I've had good luck dry-spraying SEM Trim black, or even PPG DP primer and then painting over that with semi-flat black.
I prefer to lay down 1-2 medium coats, THEN dry-spraying on top of that. Basically holding the can or gun back about 20-24" after the initial coats have flashed & "misting" the paint on to achieve texture.
Bill above used SEM's Hot Rod Black paint kit when he did my V21 in the manner he said (dry spraying)
http://www.amazon.com/SEM-Paints-Hot-Rod-Black/dp/B002O0OTTC
Overall he achieved a perfect blend of texture as well as ease of maintenance with this type of finish.  Very happy with the way it came out  :2thumbs:
First pic is wet...second pic is how it laid out after drying (kinda hard to get a good pic....)
mpd659
PPG can mix organosol black for you. I bought a pint of it in 2013 to spray my friends 68 R/T Charger tail light panel.   The mixed it in Concept DCC code # 9355
HeavyFuel
This is the best pic I could find of my orginal stuff.    :-\
66FBCharger
I picked up several cans of the Rustoleum fine textured black paint.
What do I use for primer?
Any tips or tricks so that my tailpanel comes out nice?
'69 Charger R/T 440 4 speed T5, '70 Road Runner 440+6 4 speed, '73 'Cuda 340 4 speed, '66 Charger 383 Auto
SOLD!:'69 Charger R/T S.E. 440 4 speed 3.54 Dana rolling body
Charger-Bodie
Quote from: 66FBCharger on May 28, 2015, 11:44:59 AM
Unless there is bare metal or a lot of breakthrough you won't need primer. Key is to spray it totally even. It will do the rest.
68pplcharger
Quote from: Just 6T9 CHGR on May 23, 2015, 10:18:13 AM
I used the same kit, SEM HR010, for my Car and it turned out great. I just fogged the last two coats and the texture turned out great as well. I'll try to get a close up this weekend
DixieRestoParts
Guys, a friend of mine that's restored a few high end Chargers told me the tail panel is Ditzler 9028, not Organosol. He says it's 40% gloss. He got the code from a '69 paint chart that called out the tail panel. Just thought I'd pass this along in case someone wanted to try it. I'm sure it's much cheaper than Organosol. I don't think what PPG sells today is the real stuff.
Dixie Restoration Parts
Ball Ground, Georgia
Phone: (770) 975-9898
Phone Hours: M-F 10am-6pm EST
mail@dixierestorationparts.com
Veteran owned small business
The Best Parts at a Fair Price
hemi-hampton
Here's what my 1969 PPG paint code book say's. Sorry about the watermark. LEON.
Quote from: 68pplcharger on May 28, 2015, 01:53:42 PM
Damn that looks good!  :cheers:
mopar4don
68pplcharger
Quote from: Just 6T9 CHGR on June 03, 2015, 04:20:12 AM
Thanks Just 6T9 CHGR...  Not bad for a set of hand laid strips going off of a picture downloaded from this site huh... lol
DixieRestoParts
Quote from: hemi-hampton on June 02, 2015, 11:26:22 PM
Hmm, conflicting info. I don't think my friend still has that paint chip, I'll have to ask if he does, and if he can send a pic.  Thanks for posting.
Quote from: 68pplcharger on June 03, 2015, 06:21:07 AM
Not bad at all.  Looks spot on to me.   I actually used a template off a factory V21 car...courtesy of member LeesRT on this site from CA....
:coolgleamA: :2thumbs:
DixieRestoParts
Does anyone know how many V21 cars were built/ordered in '69?
Quote from: DixieRestoParts on June 03, 2015, 07:12:04 PM
Reported 56 total XP built
Reported 337 total XS built
DixieRestoParts
Wow, in 30+ years of messing with these cars, I've never seen an original one. But, it does look cool!
Lord Warlock
So I take it organosol is unable to be shipped overseas?  I've used totally auto's spray cans of organosol for my tail panel and it came out looking just like the original did...because I painted half of it and checked texture before finishing it.  Mine was in good shape but had gotten overspray on it from when I painted the rest of the car, so had to retreat it afterwards.  One can was enough to do the whole rear panel at least two full coats, doing the v21 on the hood took more than one can but less than 2.  At 20.00 a can it seemed fair to me.  They have improved the formulation since the first time I got the spray cans, 5 or more years ago when you ordered a can, they sent 5 different spray tips with each can because it would clog the tip, the new formulation doesn't clog in the tip anymore.
To be on the safe side, I also have a quart of hot rod black from SEM sitting on my shelf, just in case I need to do it again.  I had been saving a half can of organosol for over a year (spray can) until it fell off the shelf and emptied itself on the floor to be found the next day...I was lucky it leaked pointing toward the floor and not toward the charger or I'd have been really ticked off.
