Firewall grommet
Started by fireguyfire, May 14, 2015, 11:43:18 AM
fireguyfire
I am missing the grommet in my firewall on my 68 for the hole that is rectangular in shape (2"x1 1/4") that has a curved top and bottom on the short ends of the rectangle; this hole is in behind the brake pedal area near where the steering column goes through the firewall.
Does anyone know where I can source one of these grommets, and what is that hole in the firewall for?
'66 Coronet 500
'68 Charger
'69 Sweptline Adventurer pickup
'56 Dodge Regent
Called the "Auto Trans Firewall Plug" in the plug/grommet kits. The hole is for the 4-speed clutch rod. When you have a 4-speed there's a rubber boot - otherwise there's a plastic plug. I don't know if you can buy them individually.
I spoke too soon! Look near the bottom: $5
http://www.dantesparts.com/bodplug.html
fireguyfire
Thanks as always Troy!
My body plug kit didnt come with one of these.
'66 Coronet 500
'68 Charger
'56 Dodge Regent
