How much oil?
Started by Drache, May 11, 2015, 01:05:42 PM
Drache
Changing the oil on the Dart and totally forgot what the previous owner said for an amount. I know a stock 440 takes 4+1 but my oil pan seems a little deeper than a stock pan or is that just me?
FYI the dipstick doesn't help since it's not for a 440  :slap:
Dart
Racing
Ass
Chasing
Hellion
Extraordinaire
68 RT
Just put in the 5qts, run motor, then check when hot. Add as needed.  :shruggy:
Drache
Quote from: 68 RT on May 11, 2015, 01:14:31 PM
Check what? The engine doesn't have the correct dipstick  :shruggy:
Dart
Racing
Ass
Chasing
Hellion
Extraordinaire
Drache
Not a stock motor or oil pan for sure. Tried to see if there was a number on the back but was nothing.
Dart
Racing
Ass
Chasing
Hellion
Extraordinaire
ACUDANUT
With that deep pan, I bet 7 quarts. Wait, that looks like a tranny pan, not a oil pan. Witch are we talking about ?
WHITE AND RED 69
First thing is to get a proper dipstick. Not a good idea driving around just guessing that you have enough oil.  :Twocents:
1969 Dodge Charger R/T
1999 Jeep Grand Cherokee
1972 Plymouth Duster
Quote from: ACUDANUT on May 11, 2015, 03:55:34 PM
That second pic is your trans pan..... :shruggy:
Look at your orange engine oil pan...."187" stamped into it?  If so 4 plus 1 for the filter
68X426
Please don't put motor oil in the tranny.  :rotz:
We Want to Help You.
1958 Dodge Pick Up, 383, loud
1966 Dodge Van, /6, slow
BSB67
Quote from: Drache on May 11, 2015, 01:32:25 PM
You think this is your engine oil pan?
11.68 @ 120.2 mph
Drache
Quote from: BSB67 on May 11, 2015, 05:31:17 PM
No trans pan. Havent slept in 48 hours and wasnt thinking straight
God I really need to sleep. Just forget everything .  :slap:
Dart
Racing
Ass
Chasing
Hellion
Extraordinaire
Stegs
i have what appears to be a stock pan....
If i do 5 quarts the dipstick reads add
if i do 6 quarts its level on the full mark
maybe its aftermarket but it sure looks stock
ws23rt
This is still a good question for those that have a different pan and are not sure about their dip stick.
The oil level should be at 1.5" below the pan mounting surface to read full on the right dipstick.
I needed to answer this question when I was making a custom oil pan for my motorcycle project. (426 hemi is the same as 440).
For my case I need a sight glass instead of dipstick.  Also my oil cooling system and filter location etc. requires an unknown extra amount from stock.
XH29N0G
See if this rings a bell with others.  I believe I have a pan that is 6 quart and takes an addition one for the filter.  This is on a charger not an A body, so it may not be relevant for your situation.  So I would see if you can find the number and ID the pan.
Or maybe it protects us.
scratchinfotraction
running over full will cause lots of windage and the oil rings will fill with oil and burn turning into carbon. this makes the ring "stick in the lands and cause blow-by out the pcv/breather.
I have done this 2x in the past THINKING a 6+ pan and ran over full for yrs till it had so much blow-by I did a tear down finding the rings packed/stuck in the lands.
so now any time I change oil for the first time on any mopar I do 4 quarts with filter and MARK stick. then add 1 quart and Mark stick full.
do it this way and mocking the pan up on a bench got me the 1.5" below gasket on my 440 for the correct amount with a stock windage tray.
windage tray cant do its job if the oil is to high in the pan.
everyone was telling me it was a 6 quart pan = NOT!
HeavyFuel
Quote from: scratchinfotraction on June 15, 2015, 09:18:21 AM
Good tip.......and welcome to the site.   :wave:
scratchinfotraction
Quote from: HeavyFuel on June 15, 2015, 12:52:37 PM
Hi and thank you!  :cheers:
