taller steel valve covers
Started by fizz, April 22, 2015, 04:21:17 PM
fizz
I've been told stock valve covers won't work with performance rocker arms, like Harland Sharp. Is a STEEL one made that fits?
BSB67
Yes they do.  The adjusters may or may not hit the oil baffle.  If they do, just clearance them as needed.
11.68 @ 120.2 mph
fizz
Thanks, looking for a stockish look, no logos. Chrome ok. Any reccomendations to who to get from?
justcruisin
What he is saying is the stock covers will work but you may need to clearance the baffles. FWIW I use stock covers on my 440 with .350 lobe lift. I did some measuring and I could go to around .400 before contact. But that would depend on your choice of rocker arms and thickness of gasket.
xoman60
Fizz. I got my covers from AMD.
fizz
