a518 trans mount
Started by cowboy4x4n, March 12, 2015, 01:46:45 PM
cowboy4x4n
guys,
Ive been searching for the info but all I have found is a mentioning of using a chevy trans mount instead of altering the factory cross member for this trans.  Any ideas which mount to use and bushing.
Thanks for the help.
lukedukem
this might help... i hope. it says something about the mount further down in the article
http://www.transmissioncenter.net/SwapInformation.htm
i believe cdr (charlie) has this tranny in his car. shoot him a PM or maybe he will come on and help.
Luke
1969 Charger XP29F9B226768
1981 CJ7 I6 258ci
2016 F150, 5.0, FX4, CC
cdr
the one i used is a gm,Oreilly's has them it is a urethane mount.
lukedukem
Nice pic, what vehicle info did you use to get the part from o'rielly's?
Luke
1981 CJ7 I6 258ci
cowboy4x4n
Thanks guys.  I see in one of the pix on that link a tube mount.  Can that be used if so what mount is that.  Or do i need to modify my stock one.
cdr
i think its 73 chevelle camaro
cdr
4 in diam alum driveshaft
cdr
cdr
cdr
cdr
cdr
cdr
also need torque boxes & sub frame connectors
cdr
cdr
to the OP it will be a 512 cid,,it is also a lock up converter,  OD & lock up are for cruising only,my trans builder put a bunch of diesel trans parts in it, he is a drag racer & said the trans should hold up but the od unit & converter are the weak link & said not to beat on it in overdrive or converter lock.
cowboy4x4n
yeah i heard the same about the od.  was wondering if there was any fix to this weak link.
cowboy4x4n
thanks warpspeed ill check it out
flyinlow
I used a trans mount from a early 90's Chevy 1500 2x4  pickup . Using the original Mopar spool mount would have been more of a challenge.
