512 build for 68 charger
Started by cdr, January 21, 2015, 04:51:37 PM
cdr
cutting out to max wedge & street porting
4.380" bore 4.250 stroke 6.536 H beam rod 440 SOURCE STROKER KIT
(.040 over) -24cc dish
1.320" 9.9 to1 comp
Indy single plane intake
Howards solid flat tappet .579 lift 247 @.050 duration
TREND tool steel solid lifters
440 source SUPER STEALTH heads flow 330 @ .650 lift,,,
THIS IS A STREET BUILD, yes the Charger has COLD A/C 3.91 rear gear, a518 overdrive with lock up torque converter
Holley 900 cfm EFI i might sell this set up & go with port injection.
cdr
heads done,ready to go to the machine shop
cdr
cdr
cdr
comet_666
Challenger340
Good stuff  :2thumbs:
Keep us posted on your progress !
Only wimps wear Bowties !
fy469rtse
Charlie, that's going to be a killer street engine  :2thumbs:
Keep us posted, new you would get around to this engine soon
moparnation74
Cdr,
Very nice!  This is the start of another awesome build thread!  Keep it going.
Charger4404spd
cdr
just got my block & heads back from G&G performance Co, out of Tomball texas,Chris & Joe did a great job!!! and the build begins.
cdr
cdr
cdr
WHITE AND RED 69
1969 Dodge Charger R/T
1999 Jeep Grand Cherokee
1972 Plymouth Duster
Challenger340
My favorite part....the assembly phase, is about to begin.  :2thumbs:
Looking good Charlie....keep us updated with pics.  :cheers:
cdr
got the rocker side clearance all set & will set the height for the best pattern  after the heads are on
cdr
cdr
mocked up the short block to check for clearance problems & yes i will have to do some grinding
cdr
cdr
cdr
checking piston height to set my quench at .040 with the correct thickness head gasket also rocking the piston to get the highest reading
cdr
