AC Center Vent
Started by john108, January 01, 2015, 01:35:29 PM
john108
Hi
I would appreciate suggestions on what you did, what I could do, etc.
The picture shows the center A/C vent on my 1968 Charger.
The problem is the vertical vanes are not linked and all point in any different direction, flopping easily.
The two separate halfs still rotate up and down.  They seem to be held in and pivot on a roll pin on each side.
Questions:
1. Do you think the plastic has deteriorated beyond repair?
2. Can the two separate halfs be replaced, if the roll pins can be removed and replaced without distruction?
3. Buy a new assembly?
4. Suggestions on where these parts can be obtained?
Thank you
John
moparnation74
I have one if you need a replacement.
plasticman-32
you would have to buy one
once that little metal bar comes out of place good luck on putting them back there hard to find new but im sure someone has then around
of if you go with aftermarket AC it will come with vents
gtx6970
They are not that hard to take apart and repair
