Wire Connector
Started by ODZKing, November 14, 2014, 02:08:22 PM
ODZKing
Looking for this connector. The other end to the cruise control stalk under dash. I need the piece on the wire connection, NOT at the end of the stalk. Showing pics for reference.
Anyone have one on an old piece or wiring or know where I can pic one up.
I did some searches but not sure what to call it.   :shruggy:
Pete in NH
It looks like it's a standard electronics connector called a "Molex Connector" with .090" male and female pins. If you do a search on Molex connector you should be able to find it. You can get them from many electronics distributors like Mouser at mouser.com or Digikey. If you have problems coming up with a source post back and let me know.
ODZKing
Quote from: Pete in NH on November 14, 2014, 03:12:20 PM
Duh, Molex connector. I work in braodcasting, I should have known that.
Got em!
Thanks Pete  ;)
http://www.ebay.com/itm/4-Pin-093-Male-Female-Molex-style-Pin-Plug-Connector-Assembly-for-20-14-AWG-/321538533095?pt=LH_DefaultDomain_0&hash=item4add30a6e7
ODZKing
Well, we had boxes of them at work and I found out they are NOT standard Molex connectors. They are a bit different in shape and size. As you can see the bottom one (original) is just a little bit too big to fit into the other connector, so the search continues.   :-\
Probably the Molex "Miniature" series that uses .062" pins.
Roctania
Quote from: ODZKing on November 14, 2014, 10:06:09 PM
Nothing a Dremel or saw won't cure.  get ingenious.
don't you have the male and female plastic connectors at your work?
ODZKing
Quote from: A383Wing on November 30, 2014, 10:29:13 PM
Yes, I grabbed the other side at the station think they were the same, they are not. But I did find the one I need and the entire wiring harness in fact.  Now all I need is the servo bracket to put all this back together.
I have NO idea how the PO had this on the car before. I know it is not factory but if this was a dealer install, what a hack job.  :brickwall:
